Elsawin gives this lot
Outer sill panel trim cannot be removed without destroying it.
Heat sill moulding with hot-air blower and lift off carefully.
Clean area to be bonded with petrol, treat with silicone remover and rub dry.
l Sill mouldings are only to be bonded on at room temperature.
l This involves allowing vehicle and sill mouldings to adjust to ambient temperature for at least 2 hours prior to performing work.
l Once the backing foil has been removed, the protective moulding must be fitted on the vehicle within 90 minutes.
Heat areas to be bonded with a hot-air blower to approx. 40°C.
- Detach backing from double sided adhesive tape shortly before fitting.
- Clip in and press on sill moulding.
- Vehicle must be kept at ambient temperature for 4 hours after bonding on moulding.
Hope it helps
