    larry1's Avatar
    Feb 2005
    Dublin, Ireland
    23
    MP3 Player on my Symphony -2003 Avant?
    Any idea how I can tune my mp3 player into my symphony stereo? Is it a major job , do I need add ons?
    This is the mp3 I have:
    ftp://ftp.support.acer-euro.com/stor...h%20Manual.pdf
    Many thanks
    Silverfox42badger's Avatar
    RS4 Saloon
    Dec 2006
    Hertfordshire
    21
    Hi there, Is it a Symphony II (with the 6 CD Changer built into the head unit)? If so, the accessory kits on ebay tend not to work; I tried to use an iPOD adaptor with my Symph II and because it already has the CD changer, it will not be fooled into thinking there is another external one (basically how the non-Audi adaptors work).
    I think the best solutions / cheapest solutions are either an imported FM transmitter that plugs into the headphone socket of the MP3 player and you tune your radio into that frequency, or you go for a good old reliable tape adaptor for about 3.00 from halfords.
    Dec 2003
    Clarkston, Michigan USA
    247
    Get the USA-SPEC DF-VW.
    It provides 2 seperate Aux jacks with RCA inputs for two separate MP3 players or other audio devices.
    I've used the Blitzsafe adaptor and it worked well too. I really like the USA-SPEC adaptor because it allows me to use my portable Satellite radio and iPod.
    It doesn't matter if you have the Symphony II in-dash 6 disc player. The only trick you need to know is that when you plug it into the radio you need to unplug the lowest connector on the back of the radio to force the radio to see the adaptor. It's a known problem but after you do this it should work fine.
    The Symphony II is set up to receive a 2nd CD changer in the glove box and basically these adaptors use this audio input to the radio to provide a direct audio connection.
    Trust me, it doesn't matter if you have an in-dash CD changer because that's how all A4's are built in the USA and there are tons of people on Audiworld who use different adaptors.
    If you can't find the USA-SPEC DF-VW adaptor in Europe then most likely any other adaptor will work as long as it has RCA inputs. You'll only need to buy a cable that runs for the MP3 players 3.5mm headphone jack to 2 RCA male connections.
    Oh ya, you'll need radio removal tools.
    Don't use an FM transmitter because they sound like crap compared to a direct connection.
    Good luck!
    -Dan from Detroit
    2002 A4 3.0 Tip/Quattro/Sport/Premium
    Quattro GmbH front and lower door flares | Powerchip ECU Chip
    Borla Cat-back exhaust | Hyperflow Intake | B7 RS4 Dead Pedal with RS6 Gas/Brake Pedal
    Bi-Xenon Headlamps | S4 Sideview Mirrors | Phatnoise in Glovebox
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    This would do the job, it emulates the external CD changer and only costs £40
    http://cgi.ebay.co.uk/AUX-INPUT-ADAP...ayphotohosting
