Chris NottEM Tuning
    Apr 2004
    Hampshire, UK
    93
    FM reception poor
    Hi, the FM radio reception in my systers 2002 A4 1.8T has suddenly deteriated, does anyone have any ideas as to what the problem might be ? Do they have an FM amplifier, if so is there any way of testing to see if this has failed ?
    A3 1.8t, Facelift, 5Door, Standard.
    Jun 2003
    World of my own
    9,813
    Yes the amp is integral to the HU. Worth trying an active antenna amp, cheap and easy to install.
    http://www.caraudiodirect.co.uk/aeri...tor-p-211.html
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,535
    The antenna amp is in an encapsulated block above the rear window on the saloon, and behind the trim in the luggage compartment in the Avant.
    Especially on the saloon they often crack and fail.
    The headunit provides a power feed to the antenna amp via the antenna cables (most A4's have a diverstity antenna system to improve FM reception).
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    vanbasten's Avatar
    Jun 2006
    Ballymena, Northern Ireland
    45
    Quote Originally Posted by AndyMac
    Anyone know how to fit one of these into a Concert 11 single cd player.
    What wires go where?
    timps's Avatar
    Shakersville
    Oct 2005
    Shakersville (Bury)
    235
    The part listed in that link is just a SIGNAL SEPARATION FILTER to supply 12 volts down the aerial cable to your aerial amplifier and not actually an amp.
    This would only be of help if your Concert II is not supplying 12 volts to the aerial amp so I would check this first as most problems as PetrolDave says are linked to broken amps & not usually the power supply .
    But to wire it up the white wire goes to a switched live (you can use the amp remote) which is the top plug on the concert II marked
    -o/o- next to the one marked (com) (label on top of radio shows position)
    The long silver end plugs into your aerial lead and your short black one plugs into your head unit.
    Jan 2007
    so where can i purchase an antenna amp (booster), preferably not a dealer since i think they may cost $250 to $300.
