JMB RetrofitsSky Insurance
Results 1 to 16 of 16
    tonyt102's Avatar
    Mar 2006
    Cleveland
    88
    A4 Climate control problem
    Hi there chaps.
    The climate control on my 2003 S4 is playing up...
    The passenger side climate is stuck on hot. You can still change the temp reading but it doesn't change the temp of the air. It keeps fixing its self and then coming back. I'm thinking a flap must be stuck or something.
    Has anyone had one of these out and knows where to look?
    Thanks,
    Antony.
    Jan 2005
    UK
    Sounds familiar! Happened to mine for 1 day only! You can set the temperature on the passenger side to Low - and cold air comes out, otherwise always hot.
    Got in the car the next day - was fine and hasn't come back, yet.
    2004 (53) A4 Avant Sport 1.8T (190) Quattro. Dolphin Grey, Bose, Symphony, CD SatNav, Centre Armrest, Leather/Alcantara trim.
    tonyt102's Avatar
    Mar 2006
    Cleveland
    88
    Just had the car put on VAG COM and says faulty LHS temp control flap, motor or wiring.
    The garage say they need to see the problem so they can check the feed to the motor to rule out wiring...as it is intermitent thats quite difficult.
    Has anyone had this problem?
    :: Audi S4 B6 :: 53 reg :: SILVER :: DVD SAT NAV ::
    Mcgough's Avatar
    Oct 2004
    Newcastle
    820
    if it ends up being the climate control unit, i have one that ive bought and never used!
    2010 A4 Avant B8 S-Line Executive 143ps 2.0 Tdi Ice Silver
    Extras - 5 spoke 18's, Comfort Pack, Electric Seats, Start-Stop, alcantara/leather, Silver Stitching, Factory Tints all round, Cruise control, symphony 6 disc changer, mobile phone prep low
    Previously Owned 2002 Red A4 Avant Quattro Tdi 130 , 2004 Red A4 Avant Quattro Tdi 130
    tonyt102's Avatar
    Mar 2006
    Cleveland
    88
    Thanks mate, we'll see what happens. I think it's more likley to be the flap/motor though.
    Cheers, Antony.
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Had this from my car also, i believe it was a heater flap motor
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    a4sline's Avatar
    Oct 2004
    land of Strongbow
    185
    Yep me too, was the motor on the flap.
    Nice and easy to change, just glovebox out and a couple screws.
    HTH
    It's in the DNA
    Mcgough's Avatar
    Oct 2004
    Newcastle
    820
    looks like it should be a recall?!??!?
    SteveTDCi's Avatar
    Nov 2005
    Lincs
    1,384
    Someone at work had the same problem, I cannot remeber exactly what it was - I think it was the motor, it was replaced under warranty though.
    tonyt102's Avatar
    Mar 2006
    Cleveland
    88
    I think I might just have a go at the motor if all you guys have had the same problem. You say it's quite an easy job a4sline???
    The VAGCOM did pick up on possible motor problems. It also said wiring which I doubt it is, or a sticky flap which I could check and lube when I do the motor.
    Anyone remember how much the motor was or were they all done under warranty?
    I hate these intermitent problems!
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Done under warranty but it took about 8 visits for them to find and fix it. ****ing useless they are
    Chris
    See my images @
    tonyt102's Avatar
    Mar 2006
    Cleveland
    88
    Sounds familiar.
    The garage that did the VAGCOM wouldn't commit until they see the problem.
    I'm hopefully not paying for it as I bought the car from a dealer about 6 weeks ago.
    Feb 2007
    49
    Hi, I have similar problem, in that when i start my car in the morning or evening, cold start, and drive off, there is no air coming from the ventilation, i tried to change fan speed, but nothing, then after 10 mins driving, i could feel heat coming from ventilation, but no fan. then after 45-60 mins driving, fan started to work full. any idea why this is so and what should i do? change blower motor or climate control unit? been told various opinions, 2 commons - change blower motor or climate control unit.
    Dec 2003
    Clarkston, Michigan USA
    247
    Quote Originally Posted by ozique
    The solution is to replace the blower power module. The blower works off of PWM, of which the power module then modulates the voltage to the blower motor. The issue is with the power module. It's actually a very common problem with the B6. I've had mine replaced once already and I had the same exact symptoms. It's not your climate control, do not replace it!!
    -Dan from Detroit
    2002 A4 3.0 Tip/Quattro/Sport/Premium
    Quattro GmbH front and lower door flares | Powerchip ECU Chip
    Borla Cat-back exhaust | Hyperflow Intake | B7 RS4 Dead Pedal with RS6 Gas/Brake Pedal
    Bi-Xenon Headlamps | S4 Sideview Mirrors | Phatnoise in Glovebox
    Feb 2007
    49
    blower power module?
    Hi Dan, thanks for your advice. what's blower power module look like and where can i find it? how much did you replace it and how long did it take to be replaced? thanks.
    Dec 2003
    247
    The power module is typically located near the blower itself. I believe in the A4 it's behind the glovebox. So you'll need to take out the glove box and see if you can find it. I'm not sure of the price because I had the dealer replace mine under warranty. I can find out for you.
    -Dan from Detroit
