JMB RetrofitsAH Fabrications
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,974
    high pressure fuel pump-take a look at this picture!!
    where is this high pressure pump located on the audi a4 tdi (b6)
    also if it's not working properly what are the symptoms?
    Select a picture
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    if there were a problem its a mechanical pump so physically timing must be checked. all injectors need poptesting for their opening pressure, you really need to take to a diesel expert.
    just a little a6
    peteA3tdi's Avatar
    Mar 2004
    the rose and crown
    406
    Quote Originally Posted by vw754
    Select a picture
    038 145 209e its a fuel and vacuum pump
    its at the back of the head and its one of the fuel pumps as well as the vac pump for the brake servo,vnt ect,ect
    its just an old estate (well a 500bhp estate anyway)
    vw754's Avatar
    Nov 2006
    U.K
    1,974
    if this is faulty would you get poor m.p.g and poor starting?
