EM TuningMonster Motorsport
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,973
    starting problem! tdi
    my car is taking 3-4 seconds before it starts ,it use to start as soon as the key were turned,but now takes longer
    ive been told "glow plugs" wouldnt these be for when the engine is cold?
    my car does it if engine is cold or hot,it could be running i turn it off and re-start straight away,same problem
    new fuel/air filters around 800 miles ago. Any idea's? A4 tdi (b6) 130bhp AWX Engine
    Dec 2006
    Angus
    7
    Since you have changed the fuel filter. Check the pipes and fittings around the fuel filter, including the drain plug for tightness.
    Sounds like it is drawing in air.
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    all tight,no leaks,dont know what else to do!
