starting problem! tdi
vw754
vorsprung Durch Technik
U.K
my car is taking 3-4 seconds before it starts ,it use to start as soon as the key were turned,but now takes longer
ive been told "glow plugs" wouldnt these be for when the engine is cold?
my car does it if engine is cold or hot,it could be running i turn it off and re-start straight away,same problem
new fuel/air filters around 800 miles ago. Any idea's? A4 tdi (b6) 130bhp AWX Engine
Since you have changed the fuel filter. Check the pipes and fittings around the fuel filter, including the drain plug for tightness.
Sounds like it is drawing in air.
all tight,no leaks,dont know what else to do!:crying:
