Sky InsuranceBadger5
Results 1 to 7 of 7
    Feb 2004
    Buying Audi A4 2.5 TDI Quattro
    HI all!
    if anyone can help im in the porcess of buying the above car
    any advice would be greatfull
    also does anyone know when the cambelt needs to be changed????
    Grant
    arthurfuxake's Avatar
    Controversial & Contradictive
    Mar 2004
    Manchester
    1,306
    80K Miles.
    53 A4 2.5TDi Quattro Sport 180 Tiptronic. Heated Buffalino leather, DVD Sat Nav RNS-E, TV, Bluetooth, 6 cd, BOSE, Colour DIS, Cruise Control, Auto lights and mirrors, Interior light pack, Heated mirrors.
    nivagh's Avatar
    Dec 2006
    Doncaster
    192
    Good idea to get the water pump and all the other gubbins in there replaced at the same time, since replacing the toothed belt means taking off the entire front bumper, which is quite an expensive job, so even if the water pump isn't about to keel over and die, replacing it at the same time is a precautionary measure.
    Watch also for the water temperature gauge - if it's not reaching 90 after a few minutes' driving, the thermostat or associated parts needs to be looked at, which is also quite an expensive problem to fix, apparently.
    A million-mile fall from grace; thank God we missed the ground
    VennyQuattro's Avatar
    Nov 2006
    52
    That's new to me!
    I thought the diesels took a while to warm up, mine certainly does 5-10mins in this current cold climate.
    Actually my guage fluctuates between ~75-90 degrees during normal driving, never goes a smidge above 90 though, is that something to worry about?
    nivagh's Avatar
    Dec 2006
    Doncaster
    192
    I can't really help much more on this fault I'm afraid - forum search?
    I had a 2.0 petrol until recently replacing with 2.5 tdi - the problem occurred in the last three weeks of running the petrol engine and apparently it's not uncommon. If the thermostat is not working, it will force the cooling system to work harder than it would normally, keeping the temperature low and killing your fuel economy (because it's working so hard on cooling...) My 2.0 was doing 41mpg before the fault developed and about 34 afterwards.
    When I was looking for a tdi, I found at least two cars I test drove suffering the same symptoms of low temperature readings on the gauge.
    Nov 2006
    52
    Thanks for the response.
    My economy seems fine and as the problem is only slight, I won't worry about for now, it's due for a service in a few months, so will get it looked at then.
    Nov 2006
    52
