Badger5Volks Autos
Results 1 to 8 of 8
Thread: Blown bulb
    Aug 2004
    Hampshire
    Blown bulb
    Hi,
    A4 B6.
    Just noticed that a bulb has blown near the dashboard. It illuminates half
    of the main headlight switch.
    That's not explained very well, sorry - let me expand....
    to the right of the steering wheel is the main headlight switch and when you switch on the lights, the surround is illuminated. One part of the surround (on the right hand side) is dark.
    Should be easy to replace the bulb behind but Im not sure where to start.
    Can anyone offer any clues for me? I think it's going to involve removing the lower part under the steering wheel and somehow putting my hand up inside.
    Thanks.
    Oil Burner Extraordinaire
    2001 A4 tdi 130 SE
    arthurfuxake's Avatar
    Controversial & Contradictive
    Mar 2004
    Manchester
    1,306
    The switch does come out of the dash, something about turning it to position x and then pulling it outwards. Someone on here should be able to help, if not I'll look on elsawin when I get home for you.
    53 A4 2.5TDi Quattro Sport 180 Tiptronic. Heated Buffalino leather, DVD Sat Nav RNS-E, TV, Bluetooth, 6 cd, BOSE, Colour DIS, Cruise Control, Auto lights and mirrors, Interior light pack, Heated mirrors.
    Aug 2004
    Hampshire
    that would be great - thanks a million!
    2001 A4 tdi 130 SE
    Dec 2006
    56
    I have just called Audi - Huddesfield as mine is also dark on the right had side... they say the bulbs cant be replaced and a new switch is required.. 69.00 INC VAT... as its a sealed unit...
    Seems strange... so im going to pull mine out and have a look...
    Does you Fogs Front and rear light up
    RickT
    Nov 2006
    liverpool
    703
    mine is also the same
    vanbasten's Avatar
    Jun 2006
    Ballymena, Northern Ireland
    45
    Mine too
    Dec 2006
    56
    mine did work till about 1 month ago... however my dads a4 1.9TDI Q SE was like that from day one..he thought it was normal as the fogs light up.. and it was only 3 years later when i got in it i noticed....
    Cheers..
    Jun 2006
    scotland
    6
    A few years ago the lights on the electric mirror switch went out on my Audi 80, I was quoted around 40 for a new switch as I was told that the bulbs could not be replaced. I took it to a local electronics firm who had a look, said it was diodes that had blown which they replaced for around 10. The lights were still working perfectly for the next 6 years when I sold the car. Maybe worthwhile taking the switch to be checked to see if it is diodes fitted.
    Hope this is of some help.
