Volks AutosJMB Retrofits
Results 1 to 12 of 12
Thread: BRAKE DISCS?
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,968
    BRAKE DISCS?
    How easy is it to change brake disc's front and rear? is it straight forward?
    b6 tdi
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Front ones are very easy but i think you need a special tool to move the rear piston.
    vw754's Avatar
    Nov 2006
    U.K
    1,968
    ouch!
    oh dear! always something!
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Its not too difficult as long as you have the tool.Cheaper to buy it and do them yourself than pay someone else to do it.
    Dec 2006
    56
    no special tool is required to "move" the pison (if by move you mean removing)... you just need a tool to "SCREW" back the piston when you insert new pads...
    One the front you just push the piston rod back in when some heavy duty grips and then on the rear insert the tool on the pistion contact pad and screw them back until they stop..
    Then pull on the handbrake until you feel it bites and stop... this auto adjusts the rear pads.
    The tool for example is this..
    http://www.harborfreight.com/cpi/cta...emnumber=40732
    Im sure if you search ebay you will pick one up cheap.
    RickT
    Dec 2006
    56
    Just re-read the post and i see you meant move as in screw back to oringal postion .... anyway.. the info is there now.
    RickT
    vw754's Avatar
    Nov 2006
    U.K
    1,968
    thanks RICKT
    Dec 2006
    56
    see the link above i posted..
    RickT
    Nov 2006
    52
    special tool
    You can make one using an old socket ,you just have to cut socket with a hacksaw leaving two peg's that fit the piston.Then use a ratchet and extension to screw the piston back.
    Dec 2006
    56
    nice tip!!!
    vw754's Avatar
    Nov 2006
    U.K
    1,968
    CHEERS FOR ALL THE GOOD INFO!!
    Jul 2006
    97
    when your pushing back the pistions be sure and open the cap on the resevoir bottle ,or you could flip the seals inside and end up needing a new master cylinder seen this before.People tend to top up the resevoir as the pads wear as this drops the level, but when the day comes to put in new pads and you push back the pistons you end up with too much fluid so take off the cap and push the pistons back slowly. Also i use a g-clamp for front brakes and a vise grips and patience for the rears.. .
    2.5 tdi v6 180 bhp quattro sport mystic blue.18 inch rs8 rims with black between the spokes, audi votex kit, twin chrome scorpion pipes, xennons,heated black buffalo leather sport seats,auto dimming mirrors,serious tailored remap ,ferodo ds 2500 pads front and back upgraded tarrox japan sport competition drilled and grooved discs up front , and ferodo 5.1 racing brake fluid, and about 5k of stereo
