Chris NottVolks Autos
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,968
    alarm beep help? vag-com?
    HOW do i set my alarm so it bleeps when doors are locked ???
    A4 TDI (B6) 2001
    Also which version of vag-com will do it?
    Dec 2003
    Clarkston, Michigan USA
    247
    Add a value of 1024 to the Central Convience Controller coding.
    Basically you need to recode your Module #46 / Central Convenience Control Module.
    More info found here:
    http://www.ross-tech.com/vag-com/cars/audiB6.html
    Any version of Vag-com will work since it's not on CAN and it's on the K1 K-line.
    -Dan from Detroit
    2002 A4 3.0 Tip/Quattro/Sport/Premium
    Quattro GmbH front and lower door flares | Powerchip ECU Chip
    Borla Cat-back exhaust | Hyperflow Intake | B7 RS4 Dead Pedal with RS6 Gas/Brake Pedal
    Bi-Xenon Headlamps | S4 Sideview Mirrors | Phatnoise in Glovebox
    vw754's Avatar
    Nov 2006
    U.K
    1,968
    Cheers,now thats done,how can i make the windows go up when i lock the doors via remote?
    Dec 2003
    247
    You can't make them automatically go up when you lock the door but you can control them using the remote by holding down either the lock button (close windows) or the unlock button (open windows).
    To do this it's a two step process.
    You need to check adaptation channel 62 of the Central Convenience module (module 46). Make sure the correct bits are set high or set to a value of 1. See the Ross-tech link I provided above.
    Then once you know the bits are set high for the features you want then you can recode the Central Convenience module. You will need to add a decimal value of 64 to your control module coding. You can start here and do this first and see if it works since by default the adaptation channel 62 should have all the bits set high already but this may not be the case outside of the USA.
    -Dan from Detroit
