Chris NottAH Fabrications
Results 1 to 33 of 33
Thread: What Tyres?
    VennyQuattro's Avatar
    Nov 2006
    52
    What Tyres?
    Mine uses 235/45/17s, and is due for some replacements soon.
    Just wondering what other forum members use on their rims, and would therefore recommend?
    Are Avon ZZ3's any good, they seem very reasonable?
    My only stipulation would be 'rim protection' as this really does help save the alloys from kerbing.
    Aug 2004
    Aberdeenshire
    740
    Just had a set of Good Year Excellence 235/45R17 fitted. Overall cost was about £100 per wheel. Could have got them cheaper but had already order them. These have rim protectors.
    Lots of members will say Good Year F1 GSD3. They were cheaper but personally I think they're too extreme for an A4 and they probably don't last very long.
    Nov 2006
    52
    Thanks, Do they last well then?
    Aug 2004
    Aberdeenshire
    740
    No idea as it's the first set I've fitted. They should last longer than the F1s.
    Our car came with Conti SportContact 2s and they lasted 21.5K which seems to be pretty good for a FWD diesel. I would have fitted another set of those but they would have been around £120 per wheel.
    Nov 2006
    52
    That's what is currently on mine, but like you say expensive, especially as 'apparently' the Quatrro's eat tyres faster? don't know if that's true for 'normal' driving.
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    what about a set of Dunlop SP9000, same sort of tread pattern as the Goodyear F1's.
    I had a set when I had my 'Star' design 17's, lasted about 18 months on the front and 24 months on the rear and on a Quattro too, I was well impressed.
    A4 2.5 TDi quattro sport saloon
    RNS-E DVD Nav running SW 0600 with 2007 disc including TMC function, Bluetooth Telephone, Audi iPod Interface
    18" RS6's now gone, replaced by OEM 18" S4 alloys
    Retrofit S-Line Bodykit
    Retrofit OEM Xenon's
    Retrofit Front Ambient Lighting
    Retrofit OEM Aero Wipers (thanks PJMSpeedy)
    Aug 2004
    Aberdeenshire
    740
    Quote Originally Posted by VennyQuattro
    I was led to believe that tyre life was better on the Quattros due to the power being spread to all wheels.
    I guess rears would wear out quicker but fronts slower so maybe it all balances out. Plus you always need to replace them in full sets as Quattro doesn't like big differences in tread depth.
    I think our fronts would have lasted only about 13-14K if I hadn't rotated the tyres as they were down to 4-5mm after 8k while the rears were still at 7mm. All tyres were under 3mm at 21.5K
    Aug 2004
    Aberdeenshire
    740
    Quote Originally Posted by 1210tech
    How many miles?
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    Quote Originally Posted by Macduff
    How many miles?
    flippin heck, now your askin....er.....i would hazard a guess at between 16 to 19k over the 2 years. i have always found that, although its quattro, the front go before the rear, i can't be arsed with all that swapping 'em from front to back though!
    Aug 2004
    Aberdeenshire
    740
    I guess that's because the fronts still have to do the steering and Quattro still has a front bias. You've also got the V6 which is a heavy lump. Perhaps a 1.9Q would be easier on the fronts
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    yeah, there is that!
    Mar 2005
    Republic of Ireland
    46
    I get approx 25k miles out of the contis sport contacts 2 and mine is a 1.9TDI Quattro Sport and now on my third set(4)
    Nov 2006
    52
    25K is pretty good going, and what I'd hope for as most of mileage is motorway cruising, will price up the SPs, Good Years & Conti's with my local tyre man, thanks.
    shineydave's Avatar
    Jan 2006
    Bradford, Yorkshire, UK
    912
    i have ZZ3's on my S4, one of mine had a manufacturing defect which i received a credit for, apart from that they're good tyres with adequate rim protection, original depth was 7.5mm, after 10k miles ALL (fronts and rears) are 5.0mm so i would challange the fact that fronts wear faster than rears. on that basis i would expect to replace them in about 12-14k miles
    Dave
    "If that's the Turbo Fairy knocking tell Her I'm not in"
    Mar 2003
    153
    I felt the conti's tram lined badly on the family 1.9 FWD which gave it a pretty wayward feel. I changed them to F1's on the front which don't tram line like the contis, but I'm not convinced they suit the car fully.
    F1's actually have a pretty hard compound and they are lasting very well on my S3 (well into the 20k mark now and driven hard), but they take a while to warm up and in this wet and cold weather they can be a bit hairy at times.
    To reiterate an earlier comment, you must replace all 4 on the quattro system at the same time or the diff will get cooked (expensive).
    Tyre choice never seems simple and I suggest it's because it's a car+tyre choice and even then dependent on model - ie. an SE and Sport model might suit different tyres.
    I had Avon's once upon a time a long time ago on my Golf VR6 and I couldn't wait to get shot of them - however that's an old model tyre and a long time ago...
    Aug 2004
    Aberdeenshire
    740
    Quote Originally Posted by SimonP
    I'd agree with that. Not very nice at times. So far, the GY Excellences seem to be OK in that respect.
    That's probably down to it being Quattro and the petrol power delivery being easier on tyres
    arthurfuxake's Avatar
    Controversial & Contradictive
    Mar 2004
    Manchester
    1,306
    Do ALL the tyres on a quattro have to match? Or can you have matching tyres on each axle only?
    I have an unrepairable puncture in one of my Rossos, will it be ok to put 2 new rossos on the front(or back) only, or do I need 4 new tyres?
    53 A4 2.5TDi Quattro Sport 180 Tiptronic. Heated Buffalino leather, DVD Sat Nav RNS-E, TV, Bluetooth, 6 cd, BOSE, Colour DIS, Cruise Control, Auto lights and mirrors, Interior light pack, Heated mirrors.
    Jun 2003
    World of my own
    9,813
    Replace them in pairs and you'll be fine.
    Remember the fronts do most of the breaking, quattro or not, so will always wear quicker.
    Dunlops last really well, basically because they provide absolutely no grip.
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Having had several 4wd cars, I would always advise that the tyres be the same on both axles, this is to do with differing levels of grip offered by different tyres, fit mismatched tyres at your own risk.
    Just remember that the tyres are your only contact with the road, and therefore you safety depends upon them, don't skimp on your safety.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    Nov 2006
    52
    I went for 4x Dunlop SP 9000's in the end, mainly because I didn't have time to mess about and it was what a local tyre dealer had 4 of in stock.
    About £97 per corner fitted, they seem fine, guess it just depends on how long they last, time will tell.
    As a matter of interest I fitted Michelin Pilot Primacys on my last car, they lasted a long old time, but they were'nt too hot in the wet, a very expensive tyre though, about £150 per corner for 17/235s
    Sep 2004
    ABERDEENSHIRE
    89
    got 4 no pirelli p zero rossos 235x40x18x95y fitted saturday for £499.80 at kwik fit aberdeen no one could beat their price
    Jun 2003
    World of my own
    9,813
    "guess it just depends on how long they last, time will tell."
    They'll last forever as they're Tefal coated, nice choice for wheelspinning wildly in any gear..
    Haroulli's Avatar
    Jun 2006
    East Coast USA
    31
    I replaced mine a couple of months ago on my 03 A4 1.8TQ after i had a blow out on the motorway. Sidewall on my rear Michelin gave in.
    I replaced them with Yokohama AVS ES100 which are a soft compound but so far have been pretty good in the wet and in the dry. I put them on the front.
    And moved my slightly worn Nexen N3000 to the back. These were on the front of the car when i got it. Being a name i've never heard of i figured they would be cheap and nasty but are pretty good! Not as nice as the Yoko's but still nice!
    Andy101's Avatar
    Nov 2004
    North Yorks
    166
    About 97 per corner fitted, they seem fine, guess it just depends on how long they last, time will tell.
    As a matter of interest I fitted Michelin Pilot Primacys on my last car, they lasted a long old time, but they were'nt too hot in the wet, a very expensive tyre though, about 150 per corner for 17/235s
    I wouldn'trecommend the SP9000's. I have had trouble wit uneven tyre wear on my A4 TDI (sounds like a wheel bearing but is not). This is the second set of four with the same problem. Looking to change in the next week or so...
    B8 Avant S-Line,
    Lava with 19's and a few toys.
    Gone: 2004 A4 1.9TDi Avant, 2003 Golf PD150 GTi, 2002 Golf PD150 GTi, 1999 A3 1.8T, 1983 MK1 Golf GX
    Nov 2006
    52
    Well they seem ok so far, maybe a bit more road noise than the Conti's.
    No wild wheel spinning (it is a quattro)!
    They handle ok, better than my old Celica with Primacy's on, I don't drive like a loon so I don't need F1 tyre performance!
    Jun 2003
    World of my own
    9,813
    I've never changed all 4 tyres at the same time on my quattro, had no issues in 8 years & 120k miles. Sounds like an urban myth to me (or tyre fitters dream). Maybe that's where they get all those part worn tyres from.
  28. #27
    Mar 2003
    153
    Quote Originally Posted by AndyMac
    Andy,
    Many moons ago I foolishly bought an ex-fleet A4 B5 2.8 quattro, I ended up shelling out for a rebuild of the differential, it had been cooked from running with different tyres and tread depths all round (that's fleet management for you, only allowed to change the tyre when it's illegal or the driver is dead).
    I don't recall what Audi state the tolerance is in difference between tread depth front to rear, but it's probably enough to run new and half-worn, but not new and bald. Too great a difference and the diff runs hot, which as we found, can be expensive long term, perhaps only if the diff oil changes are skimped on.
    Anyway, if I dwell too much thinking about that old piece of junk (definitely the worst car I've ever been stupid enough to buy - one of those brain-out days) I'll undo all those therapy sessions ;-).
  29. #28
    Jun 2003
    World of my own
    9,813
    That's my point when on earth are you going to replace 2 tyres and leave the other 2 bald?
    If they need replacing or are even approaching it I'd get them all changed, but to replace all 4 tyres with 10k miles left on them just because you pick up a unrepairable puncture is just ludicrous.
    Maybe you were unlucky, but I've been doing this for 120k miles with no problems. Obviously Audi will always state the "safest" option otherwise they could be sued if someone takes it to the very limit (2 bald tyres, 2 new ones). Audi suggest brake lights can only be changed at a dealer for ****sake! so pinch of salt needed as usual.
  30. #29
    Andy101's Avatar
    Nov 2004
    North Yorks
    166
    Quote Originally Posted by Andy101
    I have replaced fronts separately in between, backs lasting just about twice the mileage. Decided to run with Pirelli P Zero Rosso's this time.
    B8 Avant S-Line,
  31. #30
    Dec 2006
    35
    Which Pirellis have the red writing on, kinda think they look cool, only seen the on a couple of Porsches though?
  32. #31
    john2garden's Avatar
    Gonad
    Jul 2005
    Chester
    388
    P zero Rossos
    About 170 quid each too.
  33. #32
    A4Andy's Avatar
    Quattro-tastic. Not half.
    Jun 2006
    Glasgow - Southside
    459
    Quattro doesn't like asymmetrical tyre patterns, different tread patterns on any tyres and doesn't handle a difference in tread depth of more than 3mm with good grace.
    Running two and two shouldnt make that much of a difference to be honest, but the above is the official line.
    Currently looking to replace all of my tyres with Goodyear F1s or Toyo Proxes. The Toyos have a marginally better rating on mytyres.co.uk, but you cant fault the F1s reputation in the wet. Both have symmetrical tread patterns. Rumour is that the Toyos last longer too.
    Hope that helps.
    Andy - A4
  34. #33
    Jan 2007
    Laaaaandan
    263
    My preference would be to get either GoodYear F1 GS-D3, or if you can still find them, Toyo T1-S, which would be cheaper but are a very very good tyre. The T1-S has been superceeded by the T1-R which apparently isn't as sticky as the S, but I've never used them so don't quote me on that.
