measuring blocks?? a4 tdi
vw754
vorsprung Durch Technik
U.K
anybody tell me how to do a measuring block test using vagcom? i think cars overfuelling as theres a strong smell of diesel fumes coming from the exhasust and i think it may be tempreature sensor(so ive been told) unless you have any other idea's:uhm: A4 TDI 130 AWX ENGINE 2001 (B6)
The fuel smel is more than likely coming from either a leaking fuel filter (from the drain plug on the bottom), fuel cooler (under drivers side front sill) or a fuel tank sender seal ( under rear seat area) all easy to spot. Hope this helps
804
7
804
783
