Monster MotorsportChris Nott
Results 1 to 8 of 8
    Sep 2005
    Hants
    21
    Brake Disc Upgrade
    Anyone have any views or experience with Black Diamond Brake disc's? Thinking of going with the grooved/drilled (combination) 312mm Versions.
    AmD Stage 1 A4 1.8T Q Sport
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    I had these on a previous car and they was good.
    Sep 2005
    Hants
    21
    Thanks, is it just a straight swop for the original audi standard 288mm or other componants needed?
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    If you have 288 now you will need the carriers off a TT,S3 and some new pads.
    Sep 2005
    Hants
    21
    Carriers or calipers? I was told that disc's and pads was all i needed.
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    You use your original calipers but you need different carriers for the calipers to accept the bigger discs.
    Sep 2005
    Hants
    21
    ahh, I see, Thanks, now i,am sucking the the right tit.
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Quote Originally Posted by james0808
    Ignore the bit about TT and S3.You need the carriers but off an A6 30v or Passat 4motion.
