Volks AutosEM Tuning
Results 1 to 7 of 7
Thread: tripple Beep
    May 2006
    perth
    380
    tripple Beep
    Hi all
    on a number of occasions i have turned my 2002 A4 Tdi 130i have heard a triple (or possible quad beep) from the back. I am guessing it is coming through the speakers and i am sure it is not the frost/petrol etc. warning as that is a much stronger single beep from the front. Does any one know what this sounds is meant to signify?
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Its the alarm in the boot,very common problem.
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Sorry,it sinals your battery's are not charging i think.
    Jul 2006
    97
    My car also does this about twice a week.Only in the morning though what battery is not charging?Is this easily fixed?
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    There are two batteries inside the siren in the boot.Its behind the panel on the drivers side.I cut mine open with a junior hacksaw and the connection to one of the batteries was corroded so i cleaned it up with some sand paper,then silicone the joints back together.It now works perfect.Hope this helps.
    scoTTy's Avatar
    Essex, UK
    1,957
    Similar probs on TTs. This may help
    http://www.tt-forum.co.uk/ttforumbbs...=792942#792942
    MY2010 B8 A4 Avant 2.0TFSI quattro S-line Executive
    Honda CBR1100XX Super Blackbird
    Gone : B6 S4 (AMD stage 3), TT (APR), Golf GTi, CBR600F
    Dec 2003
    Clarkston, Michigan USA
    247
    From what I was told by the dealership the battery in the Central Locking Horn is not replaceable. I had this service done to my car about a month ago.
    The dealership ended up replacing the entire control unit when I took in(Central Locking Horn). NO MORE BEEPS!!! Woohoo!
    It appears the TT's batteries were not meant to be serviceable either. I would assume VAG used a similar if not the same control unit for the A4 so I bet the fix is the same. That would be awesome if it is because when I go out of warranty this will be good info to have.
    -Dan from Detroit
    2002 A4 3.0 Tip/Quattro/Sport/Premium
    Quattro GmbH front and lower door flares | Powerchip ECU Chip
    Borla Cat-back exhaust | Hyperflow Intake | B7 RS4 Dead Pedal with RS6 Gas/Brake Pedal
    Bi-Xenon Headlamps | S4 Sideview Mirrors | Phatnoise in Glovebox
