Sky InsuranceChris Nott
Results 1 to 9 of 9
    necroeire's Avatar
    Feb 2004
    Ireland
    1,003
    Horn replacement
    Has anyone replaced the horn of their A4? Mine sounds really crap so I purchased a replacement but don't know where it is. I know its in the front somewhere but it's very hard to see. Anyone replaced theirs?
    B6 A4 1.9TDi 130Bhp, 18" RS6 Reps, iPod ICELink, S4 Grill, S4 Door Flares
    technics100's Avatar
    Feb 2004
    Co Antrim
    773
    Just get someone to press while you look around the front of the car...can't take too long to find. On the B5 it was in behind the lower side grill on the drivers side. It had two horns, maybe one of the leads has come off one and thats why it sounds crap... I always thought the A4 horn wasn't bad..
    2003 Silver A2 1.4 TDi - 65mpg & 30 a year to tax - ;-)
    2003 Atlas Grey A4 2.0 S-line - gone
    2000 Goodwood Green S6 4.2 V8 - gone
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    They are connected to the front bumper.
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    One either side just under the headlights.Check the plugs first as technics100 said as the horn is quite loud on mine.
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    the bumper needs to come off to change the horns.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    Dec 2003
    Clarkston, Michigan USA
    247
    You don't really need to take the bumper off but it helps.
    I changed both my horns with Hella Supertones about a year ago. I took out all the lower grilles and opened the hood. You should be able to get your hand and a wrench in there to take the horns out. It's just a small bolt or nut, but I can't remember.
    The Hellas are hard to mount because they can't use the stock location without a special bracket. I suggest getting some aftermarket horns that fit in the stock location. I also had to cut off the stock connector and use simple crimp connectors to connect up to the Hellas.
    -Dan from Detroit
    2002 A4 3.0 Tip/Quattro/Sport/Premium
    Quattro GmbH front and lower door flares | Powerchip ECU Chip
    Borla Cat-back exhaust | Hyperflow Intake | B7 RS4 Dead Pedal with RS6 Gas/Brake Pedal
    Bi-Xenon Headlamps | S4 Sideview Mirrors | Phatnoise in Glovebox
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    The easiest way is to take the headlight out.Only 2 screws to take out and loosen the back 2(do not remove these).It will take about 5 minutes and the horn is easily reached.The picture is not very good it was took from a phone but you can see how much room you get.
    Dec 2003
    247
    james, good catch. I believe I took my headlights out too when I did my swap. Nice pic.
    -Dan from Detroit
    necroeire's Avatar
    Feb 2004
    Ireland
    1,003
    Hey thanks guys - if it's not raining tomorrow I'll do it then and post some pics.
