Sky InsuranceEM Tuning
    Oct 2006
    London
    S4 Cab servicing info
    Hi all,
    Thinking of trading in my A4 3.0 Cab for a S4 Cab 04 plate with 45K on the clock.
    Just wondering when the next major serivce would be (60K I think) and would this also need a cambelt change ?
    If so with the cambelt issue, I think I may give it a miss and wait for one to come along with less miles.
    By the way, any idea on servicing costs for the S4 ??
    Cheers all
    Nov 2006
    Vinny,
    The S4 has a timing chain so no cam belt to worry about.
    From what I can gather in the 6 weeks or so that I have had the car there are only two issues known:
    1 - Auxilliary Radiators (there are two, 1 behind each fog light) they leak - happened to mine now fixed under warranty
    2 - Timing chain rattle - requires replacement idel roller (I think) - not a big problem and only happens on the very early S4's apparently.
    Apart from that they are OK.
    As far as servicing is concerned here is a service schedule - hope this all helps
    LongLife Service
    Every 60,000 km
    In addition to LongLife Service:
    Tiptronic gearbox: renew ATF
    Every 24 months
    Brake fluid: Change
    After the first 36 months, then every 24 months
    Exhaust emissions test
    Every 48 months
    Telematics: Replace emergency backup battery
    Work to be completed
    Electrical System
    Check operation of front lights: Side lights, dipped beam, main beam, front fog lights, turn signals, hazard warning lights
    Check operation of rear lights: Brake lights (incl. high-level brake light), rear lights, reversing lights, rear fog light, number plate light, turn signals, hazard warning lights, luggage compartment light (several lights)
    Interior lights and glove compartment light, warning lamps, horn: Check function
    Convertible top: Check function
    Note: With convertible top open, rollover protection: Check function (every 2 years)
    Self-diagnosis: Interrogate fault memory with fault reader V.A.G 1551 or VAS 5051
    Service display: Reset; LongLife
    Telematics: Renew the emergency backup battery (every 48 months)
    Vehicle, from outside
    Tailgate/boot lid hinges: Lubricate. up to chassis no. > 080 000 model year 02
    Door arrester, lock cylinder and bonnet release catch: Lubricate
    Sun roof: Check function, clean guide rails and spray with lubricating spray
    Windscreen wiper and washer system and headlight washer system: Check washer jet settings
    Wiper blade park position: Check
    Wiper blades: Check for damage
    Tyres
    Tyres, spare wheel: Check condition and wear pattern; record tread depths
    Tyres, FL: Check condition and wear pattern; record tread depths
    Tyres, RL: Check condition and wear pattern; record tread depths
    Tyres, RR: Check condition and wear pattern; record tread depths
    Tyres, FR: Check condition and wear pattern; record tread depths
    Tyre repair set: Check expiry date
    Vehicle, from below
    Engine, gearbox, final drive, steering and protective boots: Visual check for leaks and damage
    Tiptronic gearbox: Renew ATF
    Engine oil: Drain or extract, change oil filter
    Manual gearbox/final drive: Check oil level and top up if necessary
    Final drive (automatic gearbox): Check oil level and top up if necessary
    Brake system (from below): Visual check for leaks and damage
    Brake pads: Check thickness
    Underseal: Visual check for damage
    Exhaust system: Visual check for leaks and damage, check that parts are properly secured
    Track rod ends: Check play, attachment and protective boots
    Ball joints: Check protective boots for leaks and damage
    Engine compartment
    Engine (from above) and engine compartment: Visual check for leaks and damage
    Engine oil: Fill
    Battery with magic eye: Check display and top up with distilled water, if necessary
    Windscreen/headlight washer system: Top up fluid
    Cooling system: Check antifreeze and coolant level/antifreeze specified value -25 C;
    Actual value (measured value):
    Hydraulic system: Check for leaks, check fluid level and top up hydraulic fluid if necessary
    Air cleaner: Clean housing and replace filter element
    Spark plugs: Replace
    Fuel filter: Replace
    Dust and pollen filter: Replace
    Toothed belt for camshaft drive: Check for damage and check tension
    Toothed belt for injection pump: Check for damage and tension, adjust toothed belt tension - additional work
    Poly V-belt for alternator: Replace - additional work
    Change brake fluid (every 2 years) - additional work
    Note: Never remove strainer from brake fluid reservoir
    Concluding work
    Tyre pressures on all 4 wheels and spare wheel: Check
    Store modified tyre pressure values in driver information system (DIS)
    See Owner's Manual "(DIS) store tyre pressures"
    Headlights: Check settings and adjust if necessary (ellipsoid headlights)
    Headlights: Check settings and adjust, if necessary (gas discharge headlights)
    Test drive: Perform
    (B6) Cabriolet
    Oct 2006
    London
    S4teve,
    Thanks for all this info. Was hoping to part ex my A4 but the dealer is offering me peanuts for it !!!
    Going to try to sell it privately and then will indulge in the S4.
    Enjoy yours !!!
