EM TuningVolks Autos
    Feb 2006
    UK, Lancashire
    31
    Wierd temp guage
    Hi been searching through the numerous threads on this problem but mine seems to combine them all !!
    1: If car left standing the guage will slowly reach 90, when taken for a quick drive the temp will drop to 70 or less
    2: At the moment the guage is barely leaving the 50 mark when taken for a 10 minute drive
    3: Cabin temperature seems to be unaffected,plenty of hot or cold air regardless of the guage.
    Can anyone shed any light on this for me?
    Cheers Neil
    Aug 2004
    Aberdeenshire
    740
    Given the symptoms you describe I'd say the thermostat was faulty.
    There's probably enough heat to get warm air but the engine's loosing too much heat through the cooling system. You'll probably notice an increase in fuel consumption as it's taking a lot longer to warm up.
    Dave
    Neil_S's Avatar
    Jan 2006
    Hampshire, UK
    248
    Could also be the coolant temperature sender, I posted a guide a couple of days ago on how to change this...
    G62 Coolant Temperature Sender - Replacement guide
    It would be best to get somebody with vag-com to scan for fault codes to narrow down the problem.
    Aug 2004
    Aberdeenshire
    740
    Quote Originally Posted by Neil_S
    Could be. However given the symptoms my bet would be thermostat.
