Volks AutosSky Insurance
    Sep 2006
    Staffs
    53
    worn brake pad warning on, but pads /wires are ok
    as above really, the worn brake pad symbol has been showing for the past week or so, i have checked all of the brake pads, they are hardly worn at all. I disconnected the connectors, sprayed them with wd40. Checked the wires, they seem fine.
    Still the symbol keeps showing in the dash.
    Is there anything else i need to check, as it is becoming really annoying.
    I have just ordered a cable from alpha bid, so worst case, i can hopefully turn it off that way, would be nice tgo find the root cause of the problem though.
    Cheers.
    Dec 2003
    Clarkston, Michigan USA
    247
    Try checking for fault codes...maybe it will indicate a fault in the wiring somewhere.
    -Dan from Detroit
    2002 A4 3.0 Tip/Quattro/Sport/Premium
    Quattro GmbH front and lower door flares | Powerchip ECU Chip
    Borla Cat-back exhaust | Hyperflow Intake | B7 RS4 Dead Pedal with RS6 Gas/Brake Pedal
    Bi-Xenon Headlamps | S4 Sideview Mirrors | Phatnoise in Glovebox
    Neil_S's Avatar
    Jan 2006
    Hampshire, UK
    248
    I read on another forum that the brake pad warning light illuminating can sometimes be a sign that the battery is on the way out. Not sure if this was true or not, but I changed my battery recently because I'd been having the problem and the battery was 5 years old.
    This didn't cure the problem for me, so I disconnected the sensors and sprayed them with WD40 and so far, touch wood, it hasn't displayed the warning.
    Sep 2006
    brake pedal switch comman as muck fault
    if its a auto theres two switches and some are move over to the clutch side of the pedal
    also u only get once chance to get it in proply if u press the pedal and it pops out or you pushed it to far in u have to use a new one
    Just Plain Old's Avatar
    Jun 2004
    Warwickshire
    1,257
    Hummmmm,,, I've had exactly the opposite problem. On the last 2 track days, down to the metal and off the track without even a hint of warning, until the big red one came on after the event (or during I guess)?
    In my personal opinion
