Sky InsuranceVolks Autos
Results 1 to 10 of 10
    S-T
    S-T's Avatar
    Jul 2006
    15
    VAG Com and Cruise Control
    A couple of questions for the brighter people on here.
    Is the code to enable cruise control
    engine 01
    login 11
    11463
    And is there anything else that needs enabling on a new steering wheel controller ?
    Many thanks
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,344
    Sorry. I can't help you, as I am one of the dimmer people on here.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs.
    S-T
    S-T's Avatar
    Jul 2006
    15
    me too, thats why i need help !
    Sep 2005
    Worksop, Notts
    97
    You need to code the SCM to know it has cruise. See my post on tyresmoke on how to enable and recode the various modules:
    http://www.tyresmoke.net/ubbthreads/...305/page//vc/1
    S-T
    S-T's Avatar
    Jul 2006
    15
    Quote Originally Posted by shark_90
    Right changed the steering control module, the abs warning lights are all on. will changing the code on the engine login clear this as to be honest this bit on tyresmoke about the DIS just confused me even more.
    which bits are relevant if you havent changed the DID just added a module and a cruise control stalk ?
    Many thanks
    p.s. after looking at some of the settings I think i might need the full version of VAGCOM am i right ?
    Sep 2005
    Worksop, Notts
    97
    I'm afraid you definately do need a full version of VAG-COM, yes. Your ESP and all related systems won't work until you've recoded the steering wheel control module and ESP controller as per the link I posted. You can only do that with a full version.
    Just coding the Engine ECU with 11463 won't turn off the ABS warning lights.
    S-T
    S-T's Avatar
    Jul 2006
    15
    Cheers shark_90
    Click on to this yesterday and registered it, (I suppose it will be of more use )
    S-T
    S-T's Avatar
    Jul 2006
    15
    Shark90
    Do I still have to do these if I am only fitting Cruise ?
    Go to module 16 - Steering Wheel
    Recode
    Change the second to last digit (i.e. 0xxNx - where N is the bit to change, x are your current values). If you do not currently have CC or DIS, this should be '0'.
    Make a note of the current coding!!
    Change N to '4' (i.e. 0xx4x)
    Test
    Click on 'Do it'.
    Go to module 17 - Instruments
    Go into 'Adaption - 10'
    Go to channel 19 and click on 'Read'
    Make a note of the 'Stored Value'.
    Change value to x10xxx where x is the same as it was.
    Test
    Click on 'Do It'
    S-T
    S-T's Avatar
    Jul 2006
    15
    Right sussed it, you dont need to do module 17 - Instruments if your only installing cruise
    Works a treat
    Thanks muchly shark90, more than I originally thought but well worth the extra bit of hassle.
    Sep 2005
    Worksop, Notts
    97
    No problem, glad you got it sussed. Sorry I didn't answer your question promptly, I've been working away without internet access.
    The part about 17 - Instruments is to activate DIS, if you have fitted it, so in your case it was not needed.
    All the best
