Sky InsuranceAH Fabrications
    Mar 2006
    UK
    6
    Question Centre Brake Light
    Does anyone know how to access the centre brake light to change the bulbs?
    My dash is randomly warning me that the centre brake light has failed, but then clears again after 5 minutes. I am assuming a loose bulb or connection, so want to check this first. Anyone else had this problem?
    Many Thanks
    Chris H
    Audi A4 1.8T SE (163) 2001
    jaysback's Avatar
    Mar 2006
    wilts
    54
    is that a avant or saloon?
    2008 A4 2.0 tfsi s line - garnet red, 75% exterior detailed, 75% LED conversion.
    marmite's Avatar
    Counting the Tesco Club points
    Jul 2006
    Barnet
    1,070
    Hi there
    If salloon you get it through the boot, but if that fault is coming up you may need a complete unit, as you can't change the bulbs, this is not a uncommon fault really, heard of it before,
    Best to open boot and lay on your back in it, you will be able to see how it comes out.
    Good luck
    Audi RS6 Daytona GreyLoving all 455.7BHP of her
    Mar 2006
    UK
    6
    It is the saloon.
    I've had a look and think I can see how it comes out.
    Do you know where I can order a replacement unit? Do I have to get it through a dealer or are there other sources?
    Chris H
