AH FabricationsSky Insurance
Results 1 to 9 of 9
Thread: Air Con Service
    Jul 2005
    croydon
    42
    Air Con Service
    Morning All,
    Time for an Air Con service I feel. Car is 4 years old.
    Anyone know of a good company in the Croydon
    (south London) are.
    Thanks.
    Malcolm
    bubstar's Avatar
    Jul 2004
    Surrey
    546
    Try Turners in Imperial Way
    BUB
    A4 Avant S-Line quattro - Avus Silver/Silver Half Leather *240ps*346nm* - a few choice mods. Now Stared up ;-)
    Jul 2005
    croydon
    42
    Thank you, will check them out.
    MDS
    Nov 2005
    UK
    44
    How frequent are you meant to do this? My three year old S4 is getting a bit smelly so probably time. What does an a/c service involve over and above a re-gas?
    Jul 2005
    croydon
    42
    I have to say that I am not really sure.
    Presumably, all joints/seals etc are checked, even if only visually,
    the system cleaned, re-gassed and filter changed.
    My understanding is that there is no such thing as
    a perfect seal, as light (as in not heavy) gases can escape molecule
    by molecule. If that is true then over 4 years or so
    a fair bit can leak away.
    If there is an expert out then who can add/put me
    straight I would be grateful.
    Malcolm
    marmite's Avatar
    Counting the Tesco Club points
    Jul 2006
    Barnet
    1,070
    The system will leak gas over a perod and some get used.
    Manu recommend every 2 years and now recommend Anti bacterial agent run through the system after a year, well worth it.
    On a/c sevrice they should, that is should drain the gas, check for oil removed while doing so, evaquate the system 15 - 30 min, pulls out any moister and vacumn the system, regas put some leak dye in it and do a temp check. 10min
    they should look around for leaks or signs of dye too.
    I recommend replace pollen filter too as if your doing anti bac on evaporator best change filter other wise your just going to suck crap straight back in.
    Def worth doing I do mine every year, regass and antibac
    Audi RS6 Daytona GreyLoving all 455.7BHP of her
    Nov 2005
    UK
    44
    Thanks - very helpful
    Jul 2005
    croydon
    42
    Ditto
    Malcolm
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Cheap way....
    Go to halfrauds, buy a can of R134a and a can of Comma Air Con antiBac, then follow instructions on both products, this will regass and clean your air con, and save you over 100 quid.
