Chris NottVolks Autos
Results 1 to 7 of 7
Thread: Dash lights
    Aldo's Avatar
    Jun 2006
    1,004
    Dash lights
    Just a quick questions, why do the dash lights on the speedo rev counter go dim and disapear in dark areas like under tree's etc?
    Is it to prompt you to put your lights on or something?
    I never realised they were light sensitive?
    Si
    A bit slow!!!!
    Jul 2006
    Limerick, Ireland
    21
    I think that it is an anti-glare function, because the dash lights are nice and bright to be seen easily in sunlight, and this could be bright enough to distract when in shadow. Apparently it works quite well on Alpine roads with unlit tunnels that are too short to put your lights on in.
    I think that the sensor is also the one that the climatronic uses to see which side the sun is shining from, that little button at the windscreen vent on the centre of the dashboard.
    I'm open to correction on this one though..
    Jul 2005
    2,488
    Quote Originally Posted by Aldo
    Si
    got it in one. Yes, the dash illumination is light sensitive. Its to remind you to put your lights on in the dark.
    Aldo's Avatar
    Jun 2006
    1,004
    Thanks for the replys, these cars are great! :D
    silver75's Avatar
    Big Ron
    Sep 2005
    at work
    3,243
    never knew this. I find it a bit annoying though.....
    Dec 2003
    Clarkston, Michigan USA
    247
    You can change an adaptation channel in your instrument control module to leave the dash lights on all the time. That's what I've done and it works great. Not sure if applies to you guys on the other side of the sea.
    Taken from Ross-tech's website:
    17-Instruments: K1 -- KWP-1281
    VAG-COM Works fine.
    Tweak:
    There are four lighting modes:
    Mode 0: Nothing lit until ext. light on
    Mode 1: Pointers lit all the time
    Mode 2: Scales lit all the time
    Mode 3: Pointers and Scales lit all the time
    Mode is changed in Adapation Channel 19. Standard value should be 11000 (or something close). The first (left-most) digit is the lighting mode.
    -Dan from Detroit
    2002 A4 3.0 Tip/Quattro/Sport/Premium
    Quattro GmbH front and lower door flares | Powerchip ECU Chip
    Borla Cat-back exhaust | Hyperflow Intake | B7 RS4 Dead Pedal with RS6 Gas/Brake Pedal
    Bi-Xenon Headlamps | S4 Sideview Mirrors | Phatnoise in Glovebox
    A bit slow!!!!
    Jul 2006
    Limerick, Ireland
    21
    It'll still get brighter with more ambient light, I haven't seen a way to stop the brightness changes, other than drive with the dips on.
