Monster MotorsportBadger5
Results 1 to 7 of 7
Thread: Smelly Aircon
    Feb 2005
    Scotland
    Smelly Aircon
    When I first turn my aircon on I get a damp fusty smell - is this normal?
    2003 S4
    My S3 used to smell like a new car when I turned it on!
    arthurfuxake's Avatar
    Controversial & Contradictive
    Mar 2004
    Manchester
    1,306
    you get condensation from the aircon, and if this gathers, the collected water develops bacteria which smells musty. you can buy air-con anti-bacterial spray. You release the can of spray in the car with all the windows closed and the aircon on full blast on recirc mode. this kills the bacteria and the air smells fresh again.
    53 A4 2.5TDi Quattro Sport 180 Tiptronic. Heated Buffalino leather, DVD Sat Nav RNS-E, TV, Bluetooth, 6 cd, BOSE, Colour DIS, Cruise Control, Auto lights and mirrors, Interior light pack, Heated mirrors.
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    or a bit of detol on the aircon inlet then a blast of air for a bit would do it
    just a little a6
    Feb 2005
    Scotland
    where's the aircon inlet?
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    try where the filter is douse a cloth and pin it over the inlet
    just a little a6
    A4Andy's Avatar
    Quattro-tastic. Not half.
    Jun 2006
    Glasgow - Southside
    459
    I have the same problem really with mine.
    Where are the inlets? Can someone take a photo and post it?
    Thanks in advance.
    Andy - A4
    Oct 2005
    Lancashire UK
    202
    I had a rank smell when I first turned on the blowers. It was ok when the aircon fully kicked in. I used one of those sprays too. This didn't help. I removed the bulkhead cover to notice that there was loads of rank water collecting where the battery sits. The battery was half submerged and so were some of the air con pipes and rubbers. I drained 8 litres of water away before find the drain hole (which was bunged solid) under the battery. I simply put my hand in the engine bay until I found the star shaped rubber.
    The water had gone rank with the warmer weather and the system was drawing that air in. It's unlikely to be this but worth a check.
    2001 - Silver A4 1.9TDi Sport
