Badger5JMB Retrofits
Results 1 to 16 of 16
    Apr 2006
    England
    Retrofit trip computer
    Hi All
    Im trying to find out if it is at all possible to fit a trip computer to and audi without one. I have a 2003 audi a4 sport. It already shows on the dispaly the miles left in the tank so was wondering if it was as simple as fitting a new stalk and a bit of reprogramming to get this to work.
    Looking at doing this as got audi very cheap but didnt have a few accesories that i wanted like trip computer and cruise. Already found out cruise can be fitted aftermarket and so have ordered parts to do this was wondering if i could do the trip computer at the same time.
    Done lots of searching on this and cant find much to help.
    Joel
    arthurfuxake's Avatar
    Controversial & Contradictive
    Mar 2004
    Manchester
    1,306
    Not easily(or cheaply). A whole new instrument pod is required(speedo and everything). A new wiper stalk is needed, and some minor recoding. I dunno how you'd change the mileage tho. It is possible. Check this site for info:
    http://www.navplus.us/forum/viewtopic.php?t=227
    53 A4 2.5TDi Quattro Sport 180 Tiptronic. Heated Buffalino leather, DVD Sat Nav RNS-E, TV, Bluetooth, 6 cd, BOSE, Colour DIS, Cruise Control, Auto lights and mirrors, Interior light pack, Heated mirrors.
    Sep 2005
    Portsmouth
    29
    The Dis has been retro-fitted. Check out Tyresmoke
    A4 DTM Silver....
    a4sline's Avatar
    Oct 2004
    land of Strongbow
    185
    DIS can only be fitted to a car which has 'High line' electrics. Generally the sport has 'Low line' electrics. Easy to tell which is which. If you disci=onnect the headlight switch with the ingnition on, if the headlights light up, then you have a car with 'High line'.
    Even if you buy the cruise bits, you will need to recode the steering wheel control unit and ABS control unit. Also you will have to adapt the engine control unit to the system. This can only be done VAS5052 etc.
    HTH
    It's in the DNA
    chasdrury's Avatar
    Jan 2005
    Sheffield, UK
    272
    DIS
    I have a 2004 A4 sport and have had the DIS retrofitted. i needed the wiper stalk and the steering control module - all in about 120 and access to VAGcom and someone who know what they are doing, it works perfectly.
    As said previously check out tyresmoke for details
    Chaz
    A4 2004 - 1.8TQ Limited Edition, 6 spd, Recaro Interior
    Mods - RNS-e (MK2); Rear Screens; PS2; AMI; Cruise; DIS; 18" RS6s; Carbonio CAI; Milltek CAT; Milltek CAT back Exhaust; Shark Stage 2 ReMap; RS4 RARB; HIDS; Auto Dim Rear View; RS4 Pedals, Gear Stick & Handbrake; Forge DV; Black Optics; Retro Fit Black Headlining; Retro Fit Power Folding Mirrors
    Mods to come - Memory seats; rear electric windows
    May 2006
    perth
    380
    Is there any other way to easily tell if you have high-line or low-line electrics? If not how do you get easily to the back of the switch to disconect it?
    a4sline's Avatar
    Oct 2004
    land of Strongbow
    185
    I'm not denying that you have had it retro fitted Chasdrury, but as I said, it can be fitted to a car which has hi line electrics only. If I am wrong, I'll eat my Audi Master Technician Certificate (someone who really knows what they're doing)
    Have you taken time out to check if you car is high line ? Probably not, but what do I know ?
    It's in the DNA
    chasdrury's Avatar
    Jan 2005
    Sheffield, UK
    272
    What i was pointing out was that I have a 2004 model, and had it fitted. I also said what parts were required. I did not question about hi line or low line anything
    timps's Avatar
    Shakersville
    Oct 2005
    Shakersville (Bury)
    235
    Quote Originally Posted by samuelt
    To remove the switch (very easy) push the headlight switch inwards towards the dash and at the same time turn it to the right (towards side lights on) Hold switch in this position and pull away from the dash the whole lot then pulls out.
    May 2006
    perth
    380
    thanks timps.
    I removed the switch and started the car no headlamps i guess then that this car is 'low line' A4. Is ther now way now that i can fit DIS into it?
    is it still possible to fit cruise?
    thanks
    Sep 2005
    Worksop, Notts
    97
    Quote Originally Posted by a4sline
    No need to get so shirty old boy. B6 A4's only have both highline and lowline CAN as standard, so yes, the retrofit is possible to all B6 A4's. I've done 8 to date. Joel's (who started this thread) was one of them.
    timps's Avatar
    Shakersville
    Oct 2005
    Shakersville (Bury)
    235
    Nice to see you on here as well shark_90
    Sep 2005
    Worksop, Notts
    97
    Thought I'd better come and stick my oar in over here too
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    I noticed with my sidelights, when I fitted LED bulbs they just flashed on and off regularly, I don't have DIS but I do have auto lights and xenons. Bit of a pain really as the LED's look great but the standard H6W look ****e...
    Sep 2005
    Worksop, Notts
    97
    Have you tried the PIAA sidelights? I've heard they're the best against the Xenons. I've noticed my Philips BlueVision now appear very yellow since fitting Xenons.
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    I can't say i have, will keep an eye out for them...
