Monster MotorsportEM Tuning
Thread: Radio help
    Jun 2006
    scotland
    6
    Unhappy Radio help
    Hi, I have just bought a 2003 A4 1.9 TDi, it was fitted with a Nokia phone holder which was screwed into the side of the centre console. I had no use for it so I removed the holder cut the wires connected to it, now I have found that when I put the radio on it displays "PHONE" & will not play. Does anyone have any ideas how to clear this.
    Dec 2003
    Clarkston, Michigan USA
    247
    You need to pull the connector from the back of the radio for the phone.
    It's the connector that runs vertical. There are two wires for the audio input and one for the mute line which mutes the radio. When you cut this wire you removed the voltage signal that left this pin high, which unmutes the radio.
    Make sense?
    -Dan from Detroit
    2002 A4 3.0 Tip/Quattro/Sport/Premium
    Quattro GmbH front and lower door flares | Powerchip ECU Chip
    Borla Cat-back exhaust | Hyperflow Intake | B7 RS4 Dead Pedal with RS6 Gas/Brake Pedal
    Bi-Xenon Headlamps | S4 Sideview Mirrors | Phatnoise in Glovebox
    Jun 2006
    scotland
    6
    Thanks for your help dstech, radio is now working perfectly.
    Dec 2003
    247
    Good job!
    Glad to help.
    -Dan
    -Dan from Detroit
