Monster MotorsportVolks Autos
Results 1 to 8 of 8
    Oct 2005
    Lancashire UK
    202
    Water standing in bulkhead!! PLEASE HELP
    I was checking the pollen filter as I had an awful smell coming in through the vents only to find the water hasn't been draining where the battery sits. I've just sucked out 7 litres of rank water!! I have two questions:-
    Does anyone know where the drain hole is located for the excess water to drain? I really need to knos asap to unblock it!
    Also, could there be any long term damage due to the lying water. The battery was an inch in it? All seems ok and I guess it is sealed as water always runs from windscreen.
    Many Thanks if anyone can help!
    Regards
    2001 - Silver A4 1.9TDi Sport
    necroeire's Avatar
    Feb 2004
    Ireland
    1,003
    Think I'll check mine tomorrow as I also noticed a funny smell the last few days, hope it's not blocked too. If I find the drainage hole I'll let you know.
    B6 A4 1.9TDi 130Bhp, 18" RS6 Reps, iPod ICELink, S4 Grill, S4 Door Flares
    Oct 2005
    Lancashire UK
    202
    Thanks necroeire!!!! Let me know either way what you find... Cheers
    FrankG's Avatar
    Ireland
    160
    Will have to check out mine too tonight as I have the same bloody smell, it's a pain in the ar$e as I didn't have a problem with either of my last 2 A4's. Hopefully its just blocked drains!
    Oct 2005
    Lancashire UK
    202
    More than likely FrankG, but where are those drain holes?????????
    Oct 2005
    Lancashire UK
    202
    Problem solved. I read somewhere that the drain hole was under the battery. I decided not to remove the battery and poured warm water with some soda crystal into the bulkhead. I got my hand underneath the bulkhead and felt around until I came across what felt like an inch long star shaped grommit. I stook my finger up and it was blocked, all the filth and water flew out.
    I've slewced it a few times. It seems like a worth while check every now and then to make sure the hole is clear with a finger. Hope the cabin air starts to smells a bit fresher now!!!
    Regards
    neil.c's Avatar
    Senior
    Apr 2004
    leicestershire
    564
    Quote Originally Posted by Marko
    Problem solved. I decided not to remove the battery and poured warm water with some soda crystal into the bulkhead.
    Regards
    I am sure that will do the paintwork no good
    99 S3 Absolute red
    Oct 2005
    Lancashire UK
    202
    I followed up with plenty of clean water and then rubbed dry and coated the paintwork with polish, or at least as much as I can see. It was grim in there... another week and pond life would have started.
