Rear Lights
necroeire
Ireland
What bulbs do I need for the cluster - brake, reverse & indicator?
After my light cluster went flying last week I fitted my new replacement light cluster but forgot to get the bulbs!
Got it free from Audi as it was a safety issue. They should not fly off. My guess is that the previous owner had bulbs changed by Audi and they over-tightened the screw going into the cluster and cracked the plastic housing, then it was only a matter of time.
As it was a safety issue you would think that they'd give you the bulbs as well.....after all, the cluster isn't much use without them. /ubbthreads/images/graemlins/confused.gif
I know, they dropped it off at my house yesterday so I got home and opened the box and only received the glassy bit. (Sorry if I'm too technical!)
I did save the bulb housing alright - a bit of glue has it looking almost new - well maybe 2nd or 3rd hand anyhow. But I'm missing the bulbs they were all smashed when the unit disintegrated when it hit the road. So what bulbs do I buy this lunch time?
[ QUOTE ]
[/ QUOTE ]
Pop into Halfords & consult their bulb guide. You should be find from there.
will check when i get home and post up this evening.
have gone through the whole car and worked out the whole lot.
i have some silver ind. lamps on the way and also a pair of led's type for reverse.
let you know latetrs
right here we go:-
indicator front and rear 581 / PY21W (offset pins)
reverse 382 / P21W opposite pins
stop/tail 380 / P21/5W
rear sides R5W
hope this helps you out
also it does tell you on the lamp holder as i recall.
might be worth a look /ubbthreads/images/graemlins/wink.gif
Here:
http://www.sylvania.com/ConsumerProducts/AutomotiveLighting/LampReplacementGuide/default.htm
or:
2003 AUDI A4 Sedan (With HID (high intensity discharge) headlamps)
Low beam headlamp
HID-D1S
High beam headlamp
H7
H7ST Silverstar High Performance Lighting: The Whitest and Brightest Halogen
H7XV XtraVision Halogen Upgrade: Up to 20% Brighter
H7CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
H7LL Long Life Halogen: Lasts two and a half times longer
Parking light
3457ALL
3457AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
Front turn signal
2827
3457ALL
Rear turn signal
7507A
7507AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
Tail light
5007
7528
Stop light
7528
High mount stop light
%COM
Fog/Driving light
H11-55W
License plate
6418
Back up light
7506
7506LL Long Life Upgrade: Up to twice the life of the standard lamp
Front sidemarker
3457ALL
Rear sidemarker
7528
Glove box
2825
Map light
64111
Dome light
6411
Step/Courtesy light
2825
Trunk/Cargo area
6418
Under hood light
6411
Daytime running lights
2825
416
326
12
2K
788
