Results 1 to 7 of 7
    technics100's Avatar
    Feb 2004
    Co Antrim
    773
    Where\'s the pollen filter? a picture would be good??
    I would like to change the pollen filter and don't know where it is. anyone.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,675
    Re: Where\'s the pollen filter? a picture would be good??
    Piece of cake. It's behind the bulkhead on the passenger side, accessible from under the bonnet.
    Open the bonnet, remove the rubber strip that runs along the first bulkhead, and then ease out the flat plastic panel that covers the battery, wiper motor, brake reservoir etc.
    On the right hand side of the battery, you'll see a another moulded cover, about nine inches wide & six inches deep, held in place by two clips. It also has a small piece of piping running across the top of it. Release the piping, unclip the panel & tease it out of its location. Hey presto! One pollen filter!
    If you're thinking of replacing it, try cleaning it first, save yourself 26, as per the following:
    . How to clean a pollen filter
    An added bonus is that the fresh smell of Bold Automatic now wafts through the car, LOL!
    imported_bubstar
    Never thought about washing a pollen filter.
    And I thought I was tight..................................
    BUB [img]/ubbthreads/images/graemlins/wink.gif[/img]
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,675
    [ QUOTE ]
    [/ QUOTE ]
    Not tight, just don't like giving money to Audi dealers if I really don't have to. [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Sep 2007
    How about the air filter?
    where is that located?
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Dunno mate I have a different engine to you, but surely it can't be THAT hard to find can it?? Failing that I'm sure someone will be along shortly to help you out.
    A4 TURBO UK's Avatar
    Jul 2008
    30
    Hi all
    Here are some pics...must add that they are not the best as it is pissing up here at the moment and i was taking them in the rain.
    Open bonnet and remove the plastic housing at the back of your car(if you have one)...this should expose the battery.
    [img=http://img254.imageshack.us/img254/2283/pics12072009173lj0.th.jpg]
    pic before housing is removed.
    Next picture is with the housing removed and my hand is pointing to the plastic casing that the pollen filter is in.....
    [img=http://img166.imageshack.us/img166/4267/pics12072009174yn7.th.jpg]
    There is a plastic pipe that comes from the positive side of your battery and goes threw to metal clips on the casing of the pollen filter,carefully remove from the clips and position under the pollen filter housing.On the filter housing the is 2 plastic clips with arrows on them, pull upward as the arrow suggests and by pulling towards you the housing should come straight out, you should now see the pollen filter, it will look grey/black ish depending on how long its been in there.lift out and note on the front edge of the filter the arrow denoting air flow, replace filter with arrows pointing same direction(down).
    I get mine from vagparts.com about 10 ish/+vat and delivery.
    Hope this helps folks and sorry for the bad pics.
    Cheers J
