take the plastic engine cover off (the top one on the engine not the under tray) then from the front of the car, its on the right near the back next to the cam cover
done mine earlier,its very easy.pull the two pipes off and unclip the holding clip for the other two,loosen the holding screw and lift it out.only a few dribbles of diesel leaked out aswell.its a 15 minute job.
I've sorted it! Obvious really. I read on other forums that the fuel filter had to be re-filled with fuel? I didn't do this but seems to run ok. I've only had it running in the garage for about 5 mins... How long would it take to cut if the fuel filter hadn't have filled?
