Monster MotorsportEM Tuning
Results 1 to 7 of 7
    technics100's Avatar
    Feb 2004
    Co Antrim
    772
    Advice on how to remove the top control arm pinch bolt..
    After several hours of swinging off this bolt, it still wouldn't shift. it will turn from side to side, but won't slide out. Is there any tips or ways to get these buggers out?
    here is the bolt, incase you didn't know...
    FrankG's Avatar
    Ireland
    160
    Re: Advice on how to remove the top control arm pinch bolt..
    Here ya go.....
    I too had the same problem so I had to make a trip to the parts bin and hacksaw off.
    Feb 2004
    Co Antrim
    772
    No pic..
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    undo the lock nut off completely then pull the screw head with pliers until it all the way out? might help to reduce the shearing load of the parts its holding together while removing the bolt
    mas
    Jul 2005
    n yorks
    128
    Have you jacked up the strut arm ? can reduce the effort needed.
    Basically that is a pig and sometimes the bolt has got slightly bent (ask how I know) somehow.
    We got the last one out with a punch (but carefull, the lugs on the strut can bend.)
    Feb 2004
    Co Antrim
    772
    Got it done on sat, Had to use heat on the arm. tried to shield the rubber boots, they didn't end up too bad. The bolt had nearly seized in place and came out completely dry covered in white powder. It was as if it had bonded to the aluminium arm...once out they were well greased before putting back in...buggers
    peteA3tdi's Avatar
    Mar 2004
    the rose and crown
    406
    i hope you replaced the top arms after heating them
