Chris NottVolks Autos
Results 1 to 10 of 10
Thread: 3000 rpm
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    3000 rpm
    My A4 130 tdi accelerates well between 2000 and 3000rpm then goes flat,is this normal or is there something wrong?im new to diesels.
    C_Audiboy's Avatar
    Vroom Vroom
    Nov 2004
    Glasgow
    811
    Re: 3000 rpm
    [ QUOTE ]
    [/ QUOTE ]
    That rev range is the magic window unfortunately........ pulls well in this range then dies somewhat. If you are uised to a petrol engine you will find this very different.
    It should still be pulling after 3000 RPM though, albeit not as much. If not pulling there could be a problem.
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Re: 3000 rpm
    yes im used to petrol.it still pulls past 3000 but thers is a considerable drop,will a remap sort this or will it still drop away when i reach 3000rpm?
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Re: 3000 rpm
    it was the maf,i went to chipped-uk in bromsgrove today for a remap and the maf was faulty,all i can say now is that it goes like a train,esp light doing its nut evry time i floor it and it pulls right into the red line,if anyone is thinking of a remap get your maf checked firstand contact chipped-uk,you wont believe how cheap they are too.they advertise on ukmk-iv site
    http://www.uk-mkivs.net/forums/thread/521849.aspx
    griffj's Avatar
    Oct 2005
    chester, cheshire
    105
    Re: 3000 rpm
    how much did you pay for the new maf sensor bud, and was it easy to fit?
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Re: 3000 rpm
    ive got a friend who works at vw so got it cheap [img]/ubbthreads/images/graemlins/smile.gif[/img],german,sweedish and french do them for 65+vat.they are easy to fit you just undo the pipe from the airbox to the turbo,unclip the multi plug off the maf and undo the two screws and pull it out the airbox.5 minute job.
    chazzy's Avatar
    Sep 2005
    bham uk
    95
    Re: 3000 rpm
    Hi, glad its fixed, what was the cost of the remap, did they do it via the OBD port?
    what age and mileage have you got, any clutch worries??
    did you try the car with the working MAF but before the remap?
    could be worth a write up in the tuning section?
    chas
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Re: 3000 rpm
    [ QUOTE ]
    chas
    [/ QUOTE ]
    the remap was 225 with two runs on the rollers.2001,75K and no slipping of the clutch.only found out the maf was faulty at the tuning centre so didnt drive it with 130 bhp,on the first run it was only showing 105bhp,remapped it was showing 147bhp and that was really noticeable,then put the new maf on and it was amazing,i cant stop smiling when i drive it now.
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Re: 3000 rpm
    yes it was via the obd plug thingy.
    chazzy's Avatar
    Sep 2005
    bham uk
    95
    Re: 3000 rpm
    thanks, very tempted.....
    Chas
