hi all,im new to the audi scene(from vw)and i need some bigger brakes for my A4 tdi 130.Any suggestions on what is a decent upgrade,will brakes from a R32 fit the A4?
The R32 discs and TT discs have the wrong PCD it's 5*100. The A4 is 5*112. The calipers may fit, though I've not heard it being done before.
The B5 S4 front calipers and discs are supposed to fit - plenty of guys on audiworld.com have fitted them. They are heavy though and therefore don't help handling (unsprung weight). The B6 S4 front discs and calipers also fit and are lighter than the B5 ones. Finding a second hand set might be tricky though.
Have recently replaced front rotors with same size Brembo discs and fitted Pagid Blues in the standard calipers. Braking is much improved with more precise modulation from speed. I also replaced the pads in the rear with uprated versions halfway toward the race spec ones up front.
Might be a simpler and cheaper option than what you are looking at?
[ QUOTE ]
[/ QUOTE ]
Any ideas on how much i should expect to pay for a decent set /ubbthreads/images/graemlins/confused.gif
[ QUOTE ]
i have an s4 and i will be upgrading brakes shortly, if your interested in my old ones let mr know regards tony /ubbthreads/images/graemlins/laugh.gif
