Guys, I tried to close my windows last night and they don't work even holding down the lock button on my key fob doesn't do anything!
ive checked my carpet there's no water getting into the cab as I've removed my rubber grommets and I've checked the wiring in the door (there are a couple of chaffed wires but it's just the sheathing that's cracked) the fuses are fine also!
Do you think it's the switch itself?
Just remembered it did the same the other day I turned the ignition off and back on again and they worked weird!
