Chris NottSky Insurance
Thread: Abs warning
    Oct 2010
    446
    Abs warning
    Again got car back from body shop and now the abs light is on? Any ideas why it could be on?
    Oct 2010
    446
    It's not the abs but I looks brake related it's an orange symbol where the ok normally appears
    Oct 2010
    446
    Just done scan and nothing showed. Would knocking something if wheel was removed cause a problem? Cos the Symbol should only show if the 2 wires in pads connect?
    This lowest pad is about 3 or 4mm thick. Is this at 25%?
    No Gear
    Dec 2012
    Shropshire
    333
    Connect them and see if the light goes out?
    Oct 2010
    446
    Wouldn't know how. Isn't the wires in the pad?
    Oct 2010
    446
    If the sensor was accidentally unplugged or something, would this come up? Vagcom doesn't say which pad is low or any error.
  1. ASR ABS warning lights???
    By axelfols in forum General Technical / How To
    Last Post: 16th April 2005, 08:06
  2. ABS Warning light (ECU)
    By diarmuid in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th October 2004, 23:55
  3. ABS warning light
    By jgrand in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th October 2004, 07:53
  4. Abs warning, no aircon or rev counter
    By imported_rst99 in forum General Technical / How To
    Last Post: 2nd August 2004, 09:30
  5. ABS warning light oddly coming on
    By Mutinyno9 in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th May 2004, 02:19
