JMB RetrofitsAH Fabrications
    Hodge's Avatar
    Jun 2013
    10
    VCDS and Mileage records
    As above, I know VCDS can be used to set up the mileage on a new cluster, but can it be used to check the mileage stored on the ECU of the car to check if has been altered at anytime.
    Mark Hodge
    Current Stable
    Q7 3.0 TDI
    TTS DSG
    B6 S4 Avant Manual 6spd
    Jul 2007
    London
    3,241
    Yes, on some EDC15 and 16 it will read the memory of the instrument cluster and ECU and they should be similar...
    FOR SALE:
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,492
    unless the clocker has done the job propley then theres no way to tell
    Paul @ Unit's Avatar
    Aug 2009
    north east U.K
    1,319
    Add Paul @ Unit on Facebook Visit Paul @ Unit's Instagram Channel
    you cant set the milage using vcds its vag tacho
    2003 B6 Audi A4 Avant. 3.0 V6 Quattro Sport
    Hodge's Avatar
    Jun 2013
    10
    Thanking you, it's just the trustworthiness of the ECU I was thinking of, but as you say everything is fixable, I just wondered if it recorded changes to mileage on the ECU, my car had a mileage discrepancy in the first 3 months of its life 10 yrs ago as a demo car at the Audi dealer, they appear to have inadvertently added a zero to the mileage at 6 months this became apparent at its first dealer service. But once it's on the VMR it's on, I am just looking for proof it was not clocked,
    Mark Hodge
    Current Stable
    Q7 3.0 TDI
    TTS DSG
  1. Help with vcds and checking aircon
    By markie A3 in forum Air Conditioning
    Last Post: 8th April 2011, 22:00
  2. New mileage record
    By smudge_don in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd September 2009, 16:04
  3. Re-maps and mileage?
    By Remster in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th September 2005, 21:49
  4. Miles and MPG record? Can you beat it???
    By mramage in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th August 2003, 13:15
