EM TuningSky Insurance
    technics100's Avatar
    Feb 2004
    Co Antrim
    773
    Brake Problems - Please help
    I have posted below about the lack of power in my tdi. It is infact a brake problem. The brake pedal seems to be sticking down when pressed. if you hit the brakes once and say 40 mph they will stay on until the car stops, the only way to release them is by pulling the brake pedal up with my foot.
    Also when I hold my foot on the brake pedal the pedal will sink nearly to the floor? is that normal? I don;t think it is and think it could be master cylinder, ABS pump or servo. anyone any ideas or similar problems..
    cheers
    DaveACQ20v's Avatar
    Nov 2004
    UK south west
    429
    Re: Brake Problems - Please help
    Sounds like servo to me, you`ve probably cooked your pads aswell, get it checked out m8.
    Feb 2004
    Co Antrim
    773
    Just had the master cylinder changed. No luck. Its still doing it. It seems to be pulling the pedal down when driving and causing the brake to come on and then cut the fuel - causing no power. anyone any ideas?
    imported_ChristianF
    Sounds like a duff servo, the master cylinder can't actuate itself, the servoe however can if its return spring is broken, the vacuum pump on the engine will pull the servo on.
    Feb 2004
    Co Antrim
    773
    I think the servo is the next option. I dissconnected the vacuum hose and the brakes worked fine (although they were crap because of no servo) but they stopped sticking on...
