Results 1 to 10 of 10
    Apr 2014
    North Yorkshire
    53
    A4 cabriolet boot leak
    This only started during last winter but has continued into the summer. I've read elsewhere on the interweb that this is a fairly common occurrence on the cabriolet but I have yet to find a definitive answer and I was wondering if anyone on here could help?
    Basically the boot lid panel fills up with water which pours out when you open it, both from the panel itself but also down the rubber boots carrying the cabling from the car into the boot lid. This ultimately won't be doing any of the boot lid electronics any good (and there's a surprising amount in there).
    As you can see in the photos the boot lid is level with the bodywork, the car itself is parked on the level, I have re-sealed the brake-light and the boot handle surround. The boot lid itself is fibreglass and the rubber seal is in good condition. There are no holes or damage to the boot lid or the surround, the hinges and struts all operate correctly. It can happen after rain fall, driving down wet roads or after a wash - basically any water landing on the car ends up behind the grey carpeted panel you can see in photo 5.
    All thoughts/speculation/knowledge warmly welcomed!
    A4 1.8T Quattro, Revo Stage 1, cat back custom stainless steel exhaust, B7 tail lights, A5 alloys
    Feb 2011
    Worcester, Worcestershire, United Kingdom
    46
    Mine did the very same .... You could hear the water sloshing in the boot lid !!
    They're were 3 plugs in the edge of the boot lid where it closes onto the seal I popped these out no trouble since
    The water now drains out through the bumper
    Couldn't see any reason for it sealed center brake light number plate lamps etc
    Apr 2014
    North Yorkshire
    53
    Thanks for that, I'll have a look and see if I can do the same to mine.
    I'd still be interested in any ideas as to why/how it happens?
    Feb 2011
    46
    And me can't see how or where it gets in !
    Sep 2013
    Portsmouth
    245
    Remove the boot trim and climb inside with a torch and get someone to hose the rear of the car.
    Jan 2011
    686
    I had exactly the same problem recently. I removed the red lens for the boot lid brake light, reseated it with clear silicone. Not a drop of water since.
    2003 A4 Cab 2.4 V6 Manual / 43k miles genuine woohoo (on a 10 year old car lol) / Ebony Black Metallic / Full Grey Leather / Fully Electric Seats / Heated Seats / Interior Light Pack / Cruise / Wood / Bose Symphony II / Black roof
    Apr 2014
    North Yorkshire
    53
    Quote Originally Posted by leegsi View Post
    Not sure I'm that brave! I can just see the missus taking advantage of that!
    Apr 2014
    North Yorkshire
    53
    Quote Originally Posted by Cabbyfan View Post
    Yeah, I've already done that but it's still getting in.
    Jan 2011
    686
    Try talc on the boot seal. Close lid and get the hose out. It only takes the smallest of gaps for water to get in.
    Apr 2014
    North Yorkshire
    53
    Good idea, I'll give it a try this weekend.
  1. A4 Cabriolet Water Leak - Help needed
    By MFoley in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th August 2010, 20:00
  2. CV boot leaking
    By noelg100 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2009, 11:54
  3. A4 Cabriolet Boot won't close HELP!
    By kevingallimore in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd May 2008, 16:06
  4. Fitted my new cabriolet boot spoiler today
    By andyccr in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th April 2007, 23:52
  5. CV Boot Leaking
    By conker2 in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd September 2006, 16:56
