Volks AutosBadger5
Results 1 to 7 of 7
Like Tree2Likes
  • 2 Post By dualmono21
Thread: removing rear interior from avant.
    Nov 2013
    101
    hi guys,
    can anyone tell me how to remove the side wall bits and floor from an avant? i'm wanting to put a bit of sound proofing in it as it's a bit noisey in the back and i usually drive with the radio low so i cant drown it out lol...
    done a bit of searching but cant find much... :/
    cheers.
    twed.
    B6 A4 Avant 1.9TDI Sport 130
    Dec 2006
    barnsley
    1,020
    lift up the mounting lugs on the floor ..... there are 2 screws in each one remove all
    remove the rear mounting lugs fixed on the rear panel and also remove the 2 torx screws ( lift rear panel upwards and remove)
    remove the lower rear seat bench by pulling up the front of the seat with some force about 1/3 distance of seat length
    remove the 19mm screws which fix the 3 seat belt mountings ( the middle one has a hook tag which is fiddly to remove but please make sure you remove it before folding the seat forward .... if you do not the seat belt can lock itself in the lowered position and its a nightmare to remove the seat ... YOU HAVE BEEN WARNED )
    remove the two fixing bolts which lock the folding rear sections in place (remove the locking nut first then unscrew bolt completly out
    remove the two torx screws at the base of the rear side trim panels which finish off the rear seat (be carefull when removing these pieces as some cars have air bags in these locations to remove these unclip the yellow wire )
    remove the spare wheel and centre mount floor should now be mostly accessible
    to remove side panels remove screw at rear of each side panel and use a trim removal tool on the 2 or 3 fixing points underneath
    you should then have access to sound deaden the rear compartment
    if road noise is a consideration id reccomend using a thin layer of something like dynamatt or silent coat
    followed by a 3mm layer of closed cell foam
    then either mass loaded vinyl or 3m thinsulate or both together
    this will make the rear of the car very very quiet
    good luck
    nath
    TwedA4 and Jimmy TDI like this.
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Nov 2013
    101
    legend! thanks mate. looks like i have a busy day ahead of me!
    pauldazzle's Avatar
    Cardiff
    639
    Avants aren't known for being noisy from the rear, are you sure you haven't got a wheel bearing on the way out?
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat, 165bhp remap, EGR delete, K&N panel, Dunlop SP Sport Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
    Nov 2013
    101
    i have a wheel bearing type noise on the rear but that's due to the tyres. they were exactly the same when fitted to our passat.
    this is definitely road noise. or unless it's just the tyres getting noisey on the road as they've got a few mm left..
    pauldazzle's Avatar
    Cardiff
    639
    Yeah I forgot to mention tyres as a source of noise. A lot of budget tyres are noisy & even premium tyres can rumble when the tread is getting low.
    Nov 2013
    101
    i'll see if my funds stretch for new tyres. just put avons on the front and they're nice and quiet but i drive to france next month so funds are low lol.
  1. Avant aero rear wiper... from where?
    By Geeman in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th September 2011, 11:01
  2. how do you remove the interior panel from avant tailgate ,help
    By lee red in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th March 2011, 10:17
  3. Removing rear interior side panel
    By Agent_Trig in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th March 2011, 19:03
  4. Removed rear adjusters,from weitec's
    By evocos in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th December 2009, 21:42
  5. Removing rear seats from a 60/40 A4
    By Niknak in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd July 2007, 15:57
