Volks AutosJMB Retrofits
Results 1 to 38 of 38
Like Tree1Likes
  • 1 Post By barkclark
Thread: Which lowering springs?
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    453
    Long story short as I went to replace a top mount today and heighten the from coil overs
    The coil overs are seized solid!!
    So I've decided I'm going to go the springs and shocks route with b5 perches
    But what lowering springs are people running?
    And what updated shocks if you are running them?
    I know quattrojames had the eiback kit I believe
    Should I upgrade the shocks?
    I've renewed all the arms, drop links and top mounts on the front.
    I will be doing the rear with a rs4 RARB when I do the springs
    03 Mig blue 1.9tdi 130 saloon:- GMBH front, dark tints all round, fk coilovers,
    BMW TIGERCLAWS 19" 9j front + 10j rear, debadged rear. HIDs 6k, egr delete
    cominig soon:- votex rear,front end respray, parrot kit, remap, full paint correction
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,579
    Eibach or Weitec springs for me. The Weitec spring and damper kit is very good and can highly recommend if you change the lot.
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    453
    Cheers mike
    What sort of price range we looking at here?
    Any recommended dealers?
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,579
    The last Weitec kit I bought came from AwesomeGTI, but you can also buy them direct
    Weitec Suspension Sports Coilovers and Dampers
    Mike
    - BUILD THREAD >>
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    453
    Ah right, il have a look.
    If not il price from DPM, if the springs and dampers are too expensive il just get springs.
    Dec 2011
    Somerset
    506
    It's a common money cost cutting mistake not to get new dampers.
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,298
    Just to note, Weitec has now been discontinued and replaced with ST by KW.
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    453
    Quote Originally Posted by Gazwould View Post
    I know that, but would standard dampers and lowered springs be still okay?
    I would replace the shocks anyway but depends on price wether is standard with springs or unrated springs and dampers
    barkclark's Avatar
    Nov 2013
    Scotland
    424
    I read somewhere that eibach springs are the same (or very similar) compression rate to standard sport springs. So they should work fine with OEM dampers. Anyone with further knowledge can confirm or correct this haha
    Akoya B6 A4 Avant 1.9TDi 130: 18" Audi Caressa Alloys with new centre caps, Debadged rear, Carbon vinyl front grills & gear surround, ice white sidelight/dipped beam & number plate bulbs, EGR clean & smaller gasket.
    To be fitted: B5 spring perches, Front 312mm upgrade, New CTS & Stat
    Wish List: BV43, FMIC, Organic clutch & remap!
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    453
    I know, the lad who has the white avant thread going used eiback springs on OEM dampers which what got me thinking
    barkclark's Avatar
    Nov 2013
    Scotland
    424
    I've been planning eibach pro's for a while. Just needing to get new dampers and other bits and pieces before I get them fitted!
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    453
    So you going OEM dampers or up rated?
    barkclark's Avatar
    Nov 2013
    Scotland
    424
    I'll stick with OEM mate
    Dec 2011
    Somerset
    506
    Quote Originally Posted by mattyb6 View Post
    What model is your car ?
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    453
    It's an 03 1.9tdi saloon FWD
    Dec 2011
    Somerset
    506
    Sport, SE etc ?
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    453
    SE mate
    barkclark's Avatar
    Nov 2013
    Scotland
    424
    Correct me if I'm wrong but I'm under the impression that only OEM sport dampers will work with eibachs. Not OEM SE dampers.
    Dec 2011
    Somerset
    506
    With Eibach Pro or similar go with OE Sport shocks such as Bilstein B4 or Sachs Super Touring.
    Don't use standard OE SE shocks.
    Feb 2012
    Pie eating land
    1,369
    Follow ruffrida On Twitter Visit ruffrida's Youtube Channel
    Yeh sports dampers and Eibach springs you will be sound !!
    B6 1.9tdi Quattro Avant Sport:
    My Build Thread = http://www.audi-sport.net/vb/a4-a4-c...so-begins.html
    Coming soon: -35mm Springs, Colour coded FOG grills, Trip stalk upgrade.
    Wish List; FMIC, BV43 turbo, Bigger Remap, Fat Clutch,Full Stainless, S4 Brakes, 5m mspacers - front, 10mm spacers rear, MFSW.
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    453
    So the likes of ECP will sell these, as s-line models will have these as standard
    Jan 2011
    612
    Following on from my night and day post, I really cannot recommend the Bilstein/Eibach combo I fitted last week highly enough, and when an Audi mastertech with 20+ years experience says the difference is night and day from my OEM Sport set up, that's good enough for me....
    Not cheap, but you pays your money etc etc.....
    Cheapest I could find was from Awesome GTI......
    03MY 52 reg 1.9 TDi 130PS Quattro Sport Avant - 170bhp remap, RNS-E+OEM bluetooth, B7 wiper arms/blades, 4300K HID+nightbreakers/LED sidelights, rear tints, new lights all round, new front/rear screens, frt armrest, s-line kit, cruise/DIS, B7 gearknob/aluminium trims, parking sensors, black grilles, RS4 RARB, S4 front end, black 18" RS6 alloys
    Still waiting..... S4 rear bumper, exhaust tips, coilovers, leather recaro's.... phew...
    Mar 2014
    Northants/Scotland
    46
    Quote Originally Posted by jbcalvin View Post
    Don't happen to know the part numer do you, as there's loads of um!! Lol
    also some pics with um fitted? Really wanting this kit myself, but so confused at the mo as there's so many options about at the mo....
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,618
    Quote Originally Posted by barkclark View Post
    QuattroJames ran eibach pro sport springs on OE SE shocks and reported no problems at all. So it is do-able.
    2002 2.5 V6 Quattro
    barkclark's Avatar
    Nov 2013
    Scotland
    424
    Quote Originally Posted by S4_dan View Post
    Ah I knew someone would be along to correct me! Good news for SE owners!
    Dec 2011
    Somerset
    506
    Do -able , but I seriously wouldn't recommend it.
    Eibach Pro kit spring will be more uprated than a OE Sport or S line spring.
    Sport or S line springs are more uprated than SE springs.
    Eibach spring really should have the stronger Sport dampers to control it.
  28. #27
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    I realise it's no ideal, but I can genuinely say I did it for 18 months + with no ill effects at all.
  29. #28
    Jan 2011
    612
    Quote Originally Posted by peteh View Post
    Call the guys at Awesome and let them speak to Bilstein, it took over a week for mine to arrive as Bilstein had produced a superceeded part number..... I have no idea what mine is......
  30. #29
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    453
    Been offered some eibach springs for £100 of a forum member, but there from a Quattro so don't know if they'll fit or if any has done Quattro springs on a fwd and what the differences, if any, are?
    I'm going to attempt again, to free my coilover collars on Saturday if not, il be getting some eibach sprins with s-line springs as I won't be able to afford the full kit with dampers.
    If I can free them il be laughing as the car won't be scraping anymore and by the time I get a rs4 rarb on be even better.
    I'm keep you's updated anyway
  31. #30
    Jimmy TDI's Avatar
    Pro Tinkerer
    Dec 2013
    Manchester
    384
    Soak them with plusgas (or wd40 if you can't get any) a couple of times a day for a few days, then take a hammer and chisel to them mate.
    Made on the red side of Manchester
  32. #31
    Jimmy TDI's Avatar
    Pro Tinkerer
    Dec 2013
    Manchester
    384
    Also try tapping them both ways to loosen them up
  33. #32
    barkclark's Avatar
    Nov 2013
    Scotland
    424
    Been offered some eibach springs for £100...
    Lucky sod!
    mattyb6 likes this.
  34. #33
    Jan 2011
    612
    As far as I am aware, quattro springs will not work with a FWD, more weight at the back with diffs etc so the spring rates will be completely different.....
  35. #34
    S4_dan's Avatar
    Jan 2006
    1,618
    I've got some eibach pro sport kit springs for sale in the classifieds section.
    Dan
    2002 2.5 V6 Quattro
  36. #35
    Dec 2012
    cheshire
    106
    Ive got a set of dampers off my 1.8t 190 s-line in the garage if any use? 30 quid if you want them mate
  37. #36
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    453
    Thanks for the offer mate but no thanks
    The engineers at work are going to sort my coilovers out for free.
    So can't complain really, then il see what situation I'm in after that
  38. #37
    Duck's Avatar
    Jan 2009
    Bishop Auckland, North East
    37
    Who is it selling the Eibach Quattro springs?
  39. #38
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    453
    S4 dan mate
  1. Which lowering springs to buy? Help please
    By lee_w in forum A5/S5/RS5 Forum
    Last Post: 18th November 2013, 15:43
  2. Which lowering springs??
    By KKM in forum RS3 Forum
    Last Post: 3rd July 2013, 12:54
  3. Which lowering springs b7 cab
    By Marco_b7cab in forum DPM Performance
    Last Post: 31st May 2013, 08:47
  4. which lowering springs?
    By vw754 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st April 2009, 21:01
  5. Which lowering springs for 2000 S3?
    By ScottandJo in forum Tuning
    Last Post: 14th November 2008, 12:45
