Chris NottMonster Motorsport
Results 1 to 10 of 10
Like Tree4Likes
  • 1 Post By frankc
  • 1 Post By frankc
  • 1 Post By bradh
  • 1 Post By Neilldh
Thread: Bumper alignment/removal query...
    May 2014
    Hi,
    I'm trying to remove and realign the front bumper on my Sport Avant.
    There are 3 bolts at the back of the bumper accessible via the wheel arch. However, I can't get at the passenger side as the lower part of the washer bottle is in the way.
    How do you get at that side? Do you have to remove the washer bottle? If so, how?
    May 2014
    Anyone got a guide?
    This one has no mention of the washer bottle: Audi A4 B6 Bumper Replacement | Removal And Installation | Happy Wrenching
    Are there any guides here?
    Feb 2014
    11
    Managed this on my 2004 Avant without removing the washer bottle, it was a sport bumper too. It's fiddly but I managed to fit a 10mm ring spanner down to shift the nuts a little at a time.
    Good luck
    bobsyouruncle likes this.
    May 2014
    Quote Originally Posted by frankc View Post
    Good luck
    Seriously Frank?
    I'll need to go and have another look when the wife returns, but it seemed impossible to get at when I looked this morning.
    Thanks for the reply.
    May 2014
    Good luck
    Had another look, Frank. There's absolutely no access at all.
    Did you have your car on a ramp? I'm working on the ground.
    Feb 2014
    11
    Ah, ok have you taken the headlights out? You have to remove the top two screws and then LOOSEN the two lower screws so the headlight unit slides forward so you can un-clip the wiring. Having done that you should be able to access the bumper fixings.
    Removed mins on the ground also.
    Frank
    May 2014
    Frank
    So you get at them from above by removed the headlight?
    I've had the headlight out before so I know what I'm doing in that regard.
    May 2013
    redditch b98
    358
    Add bradh on Facebook
    yes pop head lights out and 3 bolts are right there a ratchet spanner works a treat
    Neilldh's Avatar
    Jun 2011
    43
    Yep take the headlights out for access to the 3 bolts connecting to the wings, i removed my sport bumper two weeks ago and this part was straight forward. However my bumper had 5 Allen key type bolts across the front which were a nightmare to get undone as they couldn't be seen.
    May 2014
    Thanks guys!
  1. Front bumper alignment
    By Ian2012 in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st January 2013, 01:59
  2. Front bumper alignment
    By Daz4311 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 6th May 2012, 12:56
  3. Lower bumper part removal
    By Paul @ Unit in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st December 2011, 16:39
  4. Front Bumper Valance Removal
    By fran-s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th June 2010, 23:49
  5. S3 bumper/headlight removal.
    By Y83OLK in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2009, 19:04
