Volks AutosEM Tuning
Results 1 to 17 of 17
Like Tree2Likes
  • 1 Post By madmike01uk
  • 1 Post By barkclark
Thread: New shock absorbers orded
    May 2014
    Harrow
    11
    Just ordered a set of rear shock absorbers from Audi Watford,for my 2002 a4 Avant 2.5 v6 tdi sport Quattro.
    Code (8E0 513 036 AF) (oxide red colour) £195.39 all in for the pair.Should be with me tomorrow lunch time if I'm lucky...
    The question is are they fairly easy to fit?
    cheers
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    454
    Yeah, 2 13mm bolts for the top mount, then one bigger bolt holding the bottom in should take about 10mins per side
    03 Mig blue 1.9tdi 130 saloon:- GMBH front, dark tints all round, fk coilovers,
    BMW TIGERCLAWS 19" 9j front + 10j rear, debadged rear. HIDs 6k, egr delete
    cominig soon:- votex rear,front end respray, parrot kit, remap, full paint correction
    barkclark's Avatar
    Nov 2013
    Scotland
    424
    Are rear shockers an easy DIY to change then? I have one weeping oil so I think I'll order a set!
    Akoya B6 A4 Avant 1.9TDi 130: 18" Audi Caressa Alloys with new centre caps, Debadged rear, Carbon vinyl front grills & gear surround, ice white sidelight/dipped beam & number plate bulbs, EGR clean & smaller gasket.
    To be fitted: B5 spring perches, Front 312mm upgrade, New CTS & Stat
    Wish List: BV43, FMIC, Organic clutch & remap!
    Mar 2013
    Near Oxford
    406
    it's about as easy a DIY there is, hardest part is jacking the car! Some people suggest putting thread lock on the bolts.
    barkclark likes this.
    barkclark's Avatar
    Nov 2013
    Scotland
    424
    I'll do this myself then when I get me some rear shockers
    May 2014
    Harrow
    11
    Right...just got a friend to pick up my new rear shocks up and they are powder coated 'black'?
    I thought they should be red oxide in colour for a sport model? The info on them says Part number 8E0-513-036-AF and made by MONROE.
    (So I rang Monroe Uk as Audi are shut to see if they could shed any light on the matter but helpful fella on phone told me that they have never done red shocks and my car must be running aftermarket suspension?!)
    Anyone know any different?
    barkclark's Avatar
    Nov 2013
    Scotland
    424
    I was also under the impression genuine audi shocks were red oxide in colour. Are Monroe shocks what Audi use as standard from factory?
    jamesv6tdi likes this.
    kevbu's Avatar
    Aug 2010
    59
    I googled images for Audi A4 B6 sport suspension https://www.google.co.uk/search?q=au...nsion&tbm=isch
    May 2014
    Harrow
    11
    Going to try and sort this out this morning with audi parts, not that happy as i wanted to fit them this weekend.So just jacked my car up and checked the part numbers and its says 8E0 513 033 G.
    Will let you know how I get on...
    barkclark's Avatar
    Nov 2013
    Scotland
    424
    Any luck?
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,270
    I have the same car in a 2001 year and acording to vagcat the correct part numbers are 8e0 513 036g, the same as what you have on the car, there are a few different variations depending on a code in the front of your service book. This can be found on the sticker, mine says 1BE and if you look at the picture below you can match it to the part number
    I would like to know the result as i have also found the part number ending in AF listed on a different parts catalogue, what also confuses me if anyone can answer is that the shock absorber ending in part number L is the one listed for sports type suspension. Mine is a sport model and the shockers are red but does not have sports type shockers fitted acording to the list. Anyone have any explanation as i thought red where sport and black where SE spec
    May 2014
    Harrow
    11
    Update! Having a bit of a nightmare with this..I've been down to Audi and got them to order part number 8E0 513 033L listed as (gas filled shock absorber/for sports-type running gear)to compare the AF and L. I've been told it will take up to 6 days to arrive from Germany...So the wait goes on.
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    1,270
    L is only suitable for cars with a PR number of 1BD acording to vag cat, check the pr number of your car and compare to above
    May 2014
    Harrow
    11
    Right i see what you mean, just found 1 BE in my sevice book.So i wonder whats the difference is?S4 related shocks?
    Quote Originally Posted by swarcup View Post
    May 2014
    Harrow
    11
    Right just spoken to Audi head office...they have confirmed that 8E0 513 036 AF (in black) are the correct shocks for my (1 BE) coded car.
    So I can only think that Audi have stopped powder coating there sports suspension red!.. Anyway just received my new oem bump stops and dust covers from Monroe uk £20 for the two rears.Tonight's job is to fit it all!
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    1,270
    nice one thanks for confirming with audi. out of interest do they have monroe stamped on aswell
    May 2014
    Harrow
    11
    I'm sure they had the Monroe stamp on them mate.
  1. New shocks for A6 2.5TDI quattro avant
    By fjtwelve in forum Handling
    Last Post: 10th March 2012, 22:22
  2. Is this a good buy? - New shock absorbers
    By doublem_1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th February 2012, 15:47
  3. Koni FSD Shock Absorbers
    By spiker in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd August 2007, 06:38
  4. Fitting new shock absorbers
    By Ray Marks in forum General Technical / How To
    Last Post: 4th February 2007, 15:32
  5. A4 B5 Rear Shock Absorbers
    By imported_Donald_MacIver in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th April 2006, 22:30
