JMB RetrofitsVolks Autos
    Apr 2010
    6
    Issue with Drivers door lock
    Hi,
    Car's been running not to bad so not been on in a while. Its started to play up again and the latest thing is the drivers door lock.
    The battery went flat (my fault) and when trying to lock the door when I took it out to charge, it would'nt lock with the key.
    I've had a look and the cable that turns when the lock barrel is used is not connected at the bottom.
    Question is, how the blazes do you get at the door lock from inside? It seems to be behind a solid metal section?
    Lancaster
    1,780
    You need to take the frame out.
    To do: None yet.
  1. 2001 avant drivers door lock issue
    By mrnice in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 1st May 2013, 11:51
  2. Drivers door lock will not unlock with key - HELP
    By graves_x in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th April 2012, 23:39
  3. Drivers door Lock - Central locking
    By andysAko4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th February 2009, 16:51
  4. Drivers door lock not registered as locked
    By WildBruce in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th December 2008, 11:21
  5. a4 drivers door lock
    By MIDCO in forum Diesel forum
    Last Post: 5th December 2006, 12:50
