Chris NottAH Fabrications
Results 1 to 7 of 7
    Oct 2012
    Leicester (LESTA)
    57
    Exclamation Brake issue Audi A4 Cabriolet 1.8T
    Before this happened, occasionally I would get the traction control light but when restarting car, light would disappear. However, recently, I've been getting the ABS light and traction light illuminate together and once again, if I restarted the car, lights would disappear. Now driving today, the ABS or traction light hasn't illuminated, however a new light has appeared. I have attached an image taken earlier today. Hopefully someone can help me
    Abdul
    beachbuggy's Avatar
    Surrey
    1,745
    Pads
    Oct 2012
    Leicester (LESTA)
    57
    Quote Originally Posted by beachbuggy View Post
    Pads
    Hmm that maybe the case.
    Drivers side:
    Passenger side:
    They are the front axle brakes as rears were changed about 5 weeks ago. I was thinking what if it's a ABS issue or 3rd brake light switch as someone else mentioned them in another thread.
    Kind regards, Abdul
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,270
    That symbol means it's time to change the front pads, Looking at the Piccys there is what looks like 40% to 50% more ware to one side than the other poss sticky calliper and there's not a lot left on the more worn one. They should be the same thickness both sides
    Oct 2013
    13
    Would be worthwhile removing the wheels & checking the inner pads that you can't see, mine looked like they'd plenty on them when viewed thru' the wheels but the inner pads were worn..
    beachbuggy's Avatar
    Surrey
    1,745
    Pads.. It means the wear sensor on the pads is indicating they are at the limit or the plug has come undone.. If pads are ok then check the plug/wiring. It'll be one or other..
    spartacus68's Avatar
    Jan 2012
    Aberdeenshire
    56
    Complete a brake strip down and use Lockheed red grease under dust sleeves on both sides (specially formulated for hydraulic applications) for a sticky piston. If dust sleeves are torn or piston is showing signs of corrosion the you can opt for brake kit (dust sleeve, caliper 'o' ring, etc) from Audi or opt for exchange caliper. Undo the brake bleed nipple when pressing the pistons in to see if the brake fluid is dirty. Worth doing a brake bleed all round at the same time and renew the brake fluid. Also grease the sliders and check for any signs of corrosion.
    The pad signal often comes on because of damage to the wiring, not just worn pads. Found Brembo pads and discs to be excellent quality. The ABS symbol (or associated brake judder) at the same time could be dirt on the sensor or reluctor rings. Means undoing hub nut to remove from hub to wire-brush reluctor rings on cv joint, clean sensor with methylated spirits, etc. A fault code scan will identify before you go down this road.
    Is that with or without VAT?
    2001 B5 A4 2.5 TDI Avant quattro sport (155k)
    2003 A2 1.4 TDI SE (125k)
    1995 80 TDI SE Avant (175k) sold
  1. Help- Audi A6 2005, Electronic brake issue
    By mike18uk2001 in forum A6/S6/Allroad forum (C6 Chassis)
    Last Post: 7th May 2012, 17:43
  2. 1996 Audi 80 Cabriolet - Roof Problems
    By stellarborne in forum Classic Audi Forum
    Last Post: 8th July 2006, 20:30
  3. Braking Issue Please help
    By TDI in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th March 2005, 13:23
  4. Audi 80 cabriolet brake system light warning
    By imported_tacka in forum Classic Audi Forum
    Last Post: 4th March 2005, 09:39
  5. Audi A4 Cabriolet 2.5TDi
    By amoffat in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th January 2003, 03:28
