Sky InsuranceEM Tuning
Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By dale86
Thread: RNSd fitted few niggles
    dale86's Avatar
    Oct 2012
    356
    I've just fitted a RNSd which I am very happy with but it has a few niggles bugging me I only have volume on my rear speakers and it won't recognize my CD changers any help would be appreciated thanks .
    dale86's Avatar
    Oct 2012
    356
    Can anyone please help on this I've found out about the changer problem it's not compatible I need a different model bit the speakers are irritating me now and are very quiet full volume is about at what my chorus head unit was on half volume . I've also noticed o my the right hand side of the RNSd is not illuminating but the left is .
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,571
    Check cables but you may need to code the unit with as it could be in Cabriolet mode or something. Double check the coding suits your car set up
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    dale86's Avatar
    Oct 2012
    356
    Any idea where I could find the codes so I could compare them please.
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,571
    You have to plug in VCDS to the car to talk to stereo
    Mike
    - BUILD THREAD >>
    dale86's Avatar
    Oct 2012
    356
    Oh yeah I know mate I've got a friend doing it tomorrow but I was jus wondering if their is anywhere I can get hold of the codes that will need altering through vagcom.
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,571
    It gives you the options list for that unit when logged in to the module
    Mike
    - BUILD THREAD >>
    dale86's Avatar
    Oct 2012
    356
    Ok mate thanks for the info well give it a go.
    dale86's Avatar
    Oct 2012
    356
    Update on situation I've had a friend plug VCDS in and had to code front speakers in and now work spot on. On the down side a little digging found that my original CD changer is not compatable with the RNSd which is frustrating as mine is the same code but needs to have a B or C on the end grrrrrr. I have one on order from trusty eBay.DE as couldn't find one here. Happy Days
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Glad you got (getting) it sorted mate.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,005
    I never knew about the CD changer.
    Interesting.
    At least you're getting it sorted mate.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    dale86's Avatar
    Oct 2012
    356
    Yeah getting their finally lol I was wishing I'd never bothered but it's all coming together now. The next thing is to see if my cable between head unit and CD changer is compatable next I might havr to ask you to check the part num on yours James if you don't mind. When my mate read the fault codes last night one came up for the head unit it was 65535 internal control module memory error does this mean anything to anyone . Thanks for all the help so far lads .
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,005
    I got a spare CD changer cable at home you need it mate.
    Hopefully you wont.
    No idea what that error means.
    Does the unit work ok?
    Remembers radio stations and satnav address?
    dale86's Avatar
    Oct 2012
    356
    Yeah it works apart from for some strange reason the right hand side buttons don't illuminate it holds radion stations when it finds them but that's because I have a break in the Arial circuit somewhere that is another fault code that comes up but it's been their since I've owned the car I think it's the booster above the rear window. I hav not fitted the TCM unit yet I'll fit it at a later date so can't comment on the Sat nav yet. When I turn the unit on two messages pop up I think one says about the Arial and the other about TMC memory .
    dale86's Avatar
    Oct 2012
    356
    I have a extra issue to add to the list that I need advice on please. Since fittind my RNSd it seems my boot stopped opening via the boot release button on the trunk and when I put the key in and turned it to the right I would get a mighty constant siren from behind the dash almost like the noise you get if you leave your lights on when you takes keys out the ignition but a lot louder. Now the boot opening could be a coincidence but the siren.definitely not as since I have disconnected the extra wires I had to run for a RNSd install which is illuminating wire taken from headlight switch and a permanent live I've taken from the other permanent live on the head unit. My problem.seems to be with the permanent live as when disconnected it doesn't make the siren noise anymore. Anyone got a exsplaination to why this is happening ?
    dale86's Avatar
    Oct 2012
    356
    Just a update my CD changer arrived today fro EBay . De plugged it in and worked straight away so I'm a happy chappy .
    ScottD3 likes this.
  1. Couple of new bits fitted. Few pics.
    By Soupie69uk in forum A4/S4 forum(B5 Chassis)
    Last Post: 1 Week Ago, 09:08
  2. A few niggles....HELP AND ADVICE PLEASE
    By sprout99 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2014, 21:14
  3. Buying an S4 that has a few niggles
    By tonybolony in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th October 2010, 11:38
  4. A3 1.8TQ - A Few Niggles, Advice would be much appreciated
    By jcswilts in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th July 2006, 16:04
  5. Zender side skirts fitted few pics
    By concoursneil in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th June 2004, 22:10
