Chris NottVolks Autos
Thread: Permanent Live
    phil1978's Avatar
    Dec 2004
    Home of the white stilleto
    183
    Permanent Live
    Where would be the best place to pick up a permanent live for the wiring of a relay for towing electrics???
    I have taken of the shroud underneath the steering column and can see a bar with three bolts on. It looks like this would be an option, but would appreciate some guidance for the best place.
    scoTTy's Avatar
    Essex, UK
    1,957
    Re: Permanent Live
    Use your circuit tester. If you're not confident with this then get someone else to do it.
    Having said that I thought there was a ready to use point/relay for towing,
    simon_golf_tt's Avatar
    May 2004
    Fife, Scotland
    246
    Re: Permanent Live
    phil I hadn't checked the forum lately but I did answer your pm (as I got an email). Yes use the bar under the steering column with the three bolts on and the thick red wires going to it. This is the permanent 12V feed from the battery. This is what I used for my towbar electrics 12V feed to the relay box. Make sure you put an inline fuse at the 'bar' end of the cable.
    phil1978's Avatar
    Dec 2004
    183
    Re: Permanent Live
    Thanks for all your help everyone. Yep, I've got an inline fuse holder, I'll be using a 15 amp blade style. May even look if I can get it wired into the existing fusebox.
    thanks.
