hi guys as some of you may know ive had a vibration issue through the car that gets worse at higher speeds, basically ive replaced dmf and clutch, driveshafts dont look like an issue, all mounts apart from rear gearbox mount replaced, suspension looks ok and wheels where upgraded and balanced properly and the fault was still there.
no faults on vcds, so been driving it around feeling it out at speeds ect and found 2 issues firstly the vibration feels like its coming from engine bay,steering wheel spot on and it gets real bad at 70-80 but you can drive through it but when i dip clutch it fades away straight away?
secondly could be the same issue but if im cruising at a low speed say 30-40 and in a high gear like 4th where the engine like idling when i put my foot down to go the engine judders like crazy,not like its in wrong gear for speed but real bad judder?
ive put a black smoke map in it and thought i'd swap the maps and try the original and ive found the low speed judder has almost gone and the high speed vibration is still there but the wife agreed that its alot less now?
im thinking that this is an engine issue now but it idles spot on and revs very clean etc, i dont think its the black smoke map thats the issue but i think as thats pushing things like injectors maybe theres a component not up to it?
anyone got any help or advice, im thinking of taking the car for a drive with vcds and see what injectors are doing etc?
what should i be looking for?
