JMB RetrofitsChris Nott
    CEL and ESP lights
    2004 a4 1.8tq bex
    I posted a thread the other day as the cel and esp lights came on when I started the car. Scanned the car and got P0102, so I changed the MAF for a brand new one this morning rather than faff about with cleaning the old one.
    Deleted the code and cel went out, and within 200yds of driving so did the esp light.
    All was good on a 10 mile test drive, and was fine too whilst driving 20 miles to work later on. However, when I got to work I had to turn the car off to open the gates with the blipper on my keys, started the car again and both lights were instantly back on.
    Code says P0102 again, it's running fine so don't know where to look next now.
    I am really keen to get this sorted quickly as I spent a LOT of my time driving and it's so irritating! I could do with trying what I can myself at home as I need to be able to throw the car back together and go if I get called out, so a garage isn't ideal at the moment.
    The tip that solves it wins an Easter egg!
    Thanks guys.
    Feb 2011
    Ireland
    41
    Check the intake hose that connects the airbox / maf to the turbo for splits. Check particularly around the jubilee clip the connects the hose to the turbo as they tend to split around there and will throw up a similar code.
    Lancaster
    1,788
    Also check the cable for any damaged wiring.
    To do: None yet.
    Just a quick update,
    The car has started running a bit lumpy and feels to be down on power.
    Checked wiring as best I can, also checked the hoses and can't see anything unusual.
    I'm going to take the lot out later weather permitting, and check everything before refitting. I will try cleaning the maf I took out and fitting that see if it makes any difference.
  1. ABS and ESP lights on the dash all the time
    By vrbob in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st May 2010, 19:09
  2. abs and esp light on with engine management light
    By madsad1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th May 2010, 18:22
  3. ABS and ESP lights - Brake pressure sensor fault - Help!
    By wilkoa6 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 25th March 2010, 15:45
  4. ABS and ESP lights on
    By razza1 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 13th January 2010, 15:15
  5. Engine management light and ESP light on
    By AndyS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th June 2005, 14:30
