EM TuningAH Fabrications
Like Tree2Likes
  • 2 Post By davkav
Thread: 1.8T BEX Engine (190bhp) Information Thread
    Mar 2009
    81
    I put this together 2 years ago on Audizine, I figuered I may as well post it here for others.
    Over time I have found that there are a few noticeable differences between the standard A4 1.8T and the BEX. I am not getting into specifics between other engine types this thread is for the BEX only.
    The BEX was sold as a 190bhp model of the B6 A4 1.8T and was available in FWD or Quattro. The 'T' for turbo in the badge on the rear of the car coloured in red noted that the car was a 190bhp model. From the engine bay the BEX stamp on the head identified that it was a 190bhp model and the engine cover also had the 1.8T Turbo inscription in Red.
    Engine Specifications:
    • 140 kW (190 hp) @ 5700 r/min
    • 240 Nm @ 1900–5500 r/min
    Pictures for reference:
    The following differences can be found between standard models and the BEX:
    • Additional Intercooler beneath the airbox
    • Larger Turbocharger
    • Different Exhaust Manifold
    • Larger Injectors
    • Larger Front Brake Discs
    • Different Flywheel and Pressure Plate
    • 01E (Getrag) Transmission with shorter Final Drive
    Dual Side Mount Intercoolers (DSMIC)
    • Stock Single Mounted Intercooler Part Number 8E0145806F / J
    • BEX Second Mounted Intercooler Part Number 8E0145805Q
    Link to VAGCAT.com
    DIY of Second Intercooler install
    Picture of my DSMIC before I fitted my front mount. (the ole green machine in the background, that was a great car!)
    Picture from ETKA for reference:
    Turbocharger
    • Stock Turbocharger K03 Part Number 058145703J
      Specifications:
      Compressor:36/50
      Turbine: 40/45
    • BEX Turbocharger K03S Part Number 06B145703B
      Specifications:
      Compressor: 38/51
      Turbine: 40/45
    Link to VAGCAT.com
    And for comparative purposes:
    K04-015 Specifications:
    Compressor: 38/51
    Turbine: 42/46
    Exhaust Manifold
    • BEX Part Number 06B 253 033AH
    • Stock Part Number 06B 253 033E
    Link to VAGCAT.com
    It seems from this thread that the manifolds are actually the same size. So the only real difference might just be the strength of the manifold it self.
    Injectors
    • Stock Injectors 282cc Part Number 06B133551M
    • BEX Injectors 317cc Part Number 06A906031BA
    Link to VAGCAT.com
    Note: Injector size taken from USRT website here.
    Front Brake Discs
    • Stock Discs for US Market are 288mm
    • BEX and BFB Engined Discs are 312mm
    • Stock Carrier Part Number 4B0615125B
    • BEX Carrier Part Number 4B0615125C
    • Stock Brake Disc Part Number 4A0615301C
    • BEX Brake Disc Part Number 4B0615301A
    Link to VAGCAT.com
    Flywheel
    • Stock Flywheel Part Number 06B105266A (BFB), 06B105266E (AWA Chasis Number >> 8E-4-300 000), 06B105266F (AWA Chasis Number 8E-4-300 001>>)
    • BEX Flywheel Part Number 06B105266B
    Link to VAGCAT.com
    I have no information as of yet about what the difference is between the standard and BEX flywheel. I reckon it is probably the weight of the flywheel. I am going to weigh my one at some stage and report back. In the mean time if someone could weigh there standard flywheel so we can compare that would be great.
    Clutch Pressure Plate
    • Stock Part Number 06B141117D(X)
    • BEX Part Number 06B141117B(X)
    Link to VAGCAT.com
    Again not much information available here. The clutch disc seems to be the same for all engine codes so I would say there is slightly more clamping force on the BEX pressure plate.
    Transmission
    Gearbox Code for the BEX is GDZ/HER
    • Gearing for 02X Transmission
      1st 3.67
      2nd 2.05
      3rd 1.37
      4th 1.03
      5th 0.80
      6th 0.66
      Final Drive 4.11
    • Gearing for BEX 1.8T 01E Transmission
      1st 3.50
      2nd 1.89
      3rd 1.32
      4th 1.03
      5th 0.86
      6th 0.73
      Final Drive 4.38
    Link to VAGCAT.com
    Graph and data of 01E against 02X
    ECU
    There seems to be different ECU part number for different engines also. Presumably this is just a software difference to accommodate different injector sizes and turbocharger sizes.
    Pictures of BEX Connecting Rods
    This is as much information as I have so far. If anyone has anything to contribute that would be great and I will try and keep this post as up to date and factual as possible.
    Also if you register on vagcat.com (online version of ETKA) all of the vagcat link I have posted above will link to the relevant exploded diagrams and part numbers.
    quattrojames and k909068 like this.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Nice one, thank you.
    I will put a link to this thread in the DIY Guides and FAQ sticky.
  1. A4 BEX engine required!!!!!!!
    By shaz-raul in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th May 2014, 11:12
  2. BEX engined A4 190 1.8t boost problems (dealer has confused me!!!)
    By thetroublemaker in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th October 2011, 15:36
  3. A4 dual mass flyhweel for BEX engine
    By Ryanmt in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th March 2011, 11:46
  4. Remap on a 190 BEX engine - Celtic Tuning?
    By j033y in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd April 2010, 18:47
  5. A4 190ps (BEX engine) Diverter Valve location
    By imported_bubstar in forum Tuning
    Last Post: 24th January 2005, 22:01
