Results 1 to 11 of 11
    Apr 2014
    7
    Audi a4 quattro diferencial issues
    Hí audi fans,
    See if you can help me out, i have a audi a4 avant 2.5 quatro b6 with a diferencial problem ( i feel a clumck in the back of the car ) ,and in audi they say that is the differential support and have to take a new diferencial because the suport is sold with the diferencial all together.
    Is it for real?
    Thank´s folks
    Mar 2009
    81
    Rubbish, the mount is separate to the differential housing. You can buy uprated ones also. Apikol over in the states have aftermarket firmer ones.
    Mar 2009
    81
    Part #7 in this link is usually what fails. Id get it up on axle stands or a ramp and have a look to see if it is worn.
    Link
    Apr 2014
    7
    Quote Originally Posted by davkav View Post
    Link
    Thank´s very much for the help, I will see if it really is that mount , well i hope so because when in 1 and 2 gear i heard in back that clumck noise, right in the middle of rear seat...
    Mar 2009
    81
    No problem. Hopefully thats all that it is.
    trevor.oostendorp.9's Avatar
    Apr 2014
    Hi Gents! I've got a problem with my A4 2.0T 2006. Somehow while the car is cold it's got a little jerk,but asa it reach the 90 running temp it's gone. Then while I'm driving the temp gauge will move to the left just a little and the jerk is back. Now I've had the car at Audi ,but they can't pin point what problem is. Some suggest its my injectors,but its an expensive exercise to change them and then the problem consist. Can anybody help?
    Using Tapatalk
    Apr 2014
    7
    Gone today to audi dealer, the problem is a new torsen ( located in the gearbox...nice work ,lolll
    Need a new torsen to my car, please...
    Mar 2009
    81
    Quote Originally Posted by pt102900 View Post
    Really?! Cant believe thats the source of the problem? How much is a new torsen as I have two sitting up spare here and they are fairly easy to swap out, no need to remove the gearbox or anything.
    Mar 2009
    81
    Quote Originally Posted by trevor.oostendorp.9 View Post
    What do you mean by 'jerk'. Does it hesitate when you try to accelerate?
    Apr 2014
    @davkav it's not like its hesitating,more like the engine is misfiring...........when I drive with low refs,one can feel it,but as soon as the refs goes more than 2500 it smooths out......then like I mentioned as soon as the car reaches its operating temp it's a dream to drive again.
    Using Tapatalk
    Sep 2009
    34
    how did you get on with the new torsen,did this cure your problem as I am experiencing the same symptoms and if you don't mind how expensive was it
  1. Underside of Audi A3 Quattro Sport 3.2
    By Rozz in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th December 2003, 11:37
  2. if you know something about the audi 90 quattro
    By brokensaab in forum Classic Audi Forum
    Last Post: 8th October 2003, 16:33
  3. FOR SALE: AUDI 90 QUATTRO
    By faene42 in forum Classic Audi Forum
    Last Post: 17th September 2003, 04:58
  4. Audi Nuvolari quattro Concept
    By Road Razor in forum Other Brands & Models
    Last Post: 10th March 2003, 11:42
  5. Thank Audi for Quattro/ESP
    By S3Bangs in forum General Chat
    Last Post: 10th January 2003, 09:26
